comcamel LXF regular
Posted: Fri Jun 03, 2005 9:07 am Post subject: Booting Linux (PROBLEM) |
At school, i am pretty sure that all computers cannot boot from a floppy disk and the cdrom and they have locked the bios, is there anyway or any program that can run in windows which can boot a live cd distro. such as knoppix.
greatful for an answer! COmcamel |
alloydog LXF regular
Posted: Fri Jun 03, 2005 9:44 am Post subject: RE: Booting Linux (PROBLEM) |
Look at http://www.linux.org and goto the Distributions page
Under the Catergory menu, you can select Runs on MS Windows.
It found these:
• LoopLinux
• muLinux
• Xteam Linux
• Pklinux
• Tomukas
• TopologiLinux
• Cooperative Linux (aka coLinux)
• Klinux
• AMIGO Linux OS
Brief descriptions, and details where the hom epages are, and where to downlaod are also given. Check it out. |
Nigel LXF regular
Posted: Fri Jun 03, 2005 2:09 pm Post subject: RE: Booting Linux (PROBLEM) |
I've used TopologiLinux... it still needs to boot from CD. It uses a big file on your Windows disk instead of a Linux partition, so avoids all the partitioning hassles. It had it's uses... until I discovered Knoppix ! _________________ Hope this helps,
Nigel. |
towy71 Moderator
Posted: Fri Jun 03, 2005 3:15 pm Post subject: RE: Booting Linux (PROBLEM) |
if I remember rightly zipslack works from a directory in c: under windows _________________ still looking for that door into summer |
Posted: Wed Jun 08, 2005 8:25 pm Post subject: RE: Booting Linux (PROBLEM) |
| it is actually alright, today i tested out that i can use a floppy, cd drive disabled aswell as booting from memory key, i will create a knoppix boot disc, as described in the manual - and i'll be advertising linux to the class. I might have a go with a harddisk version but knoppix works well thanks! |
nelz Moderator
Posted: Wed Jun 08, 2005 9:18 pm Post subject: RE: Booting Linux (PROBLEM) |
Put Smart Boot Manager on a floppy and you'll be able to boot any CD. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
