setting up a file server
Postby prox » Wed Jun 08, 2005 5:31 pm
I am trying to set up a file server for home. i have a little experianvce with linux as have set up a couple of apache servers but i am not sure what distro wuld be the easiest for a file server. i thought of using mandrake 10.1 as this is what the apache that i made used but am not sure as struggled to find a lot of documentation on the web. does anyone have any ideas or suggestions?
ta
prox
Postby M0PHP » Wed Jun 08, 2005 5:51 pm
You didn't say what clients you will be serving to, so I'm assuming you mean Windows. If it's going to be a dedicated box, you can use ClarkConnect or SME Server (contribs.org) which are excellent file servers. Both of these have samba for windows networking, and SME can even act like an NT domain controller. Neither of these have a local GUI, but have a web-based interface to manage the server.
M0PHP
Postby linuxgirlie » Wed Jun 08, 2005 7:33 pm
If you are using mandrake try karoshiathome, we wrote it for peope with no linux knowledge. It is in its early stages but in fully working order. You can find it : www.karoshiathome.org.uk and afterwards you can have a play around. It servers both Linux and Windows clients with both static ips and dchp...
Hope this helps.
linuxgirlie
Postby M0PHP » Wed Jun 08, 2005 9:13 pm
Sorry Jo, should have suggested that first 8)
M0PHP
Postby Guest » Wed Jun 08, 2005 9:13 pm
ta. yes i am going to be serving to windows but also i have a linux box desktoop/apache running mandrake will that be able to access these programs as well
Postby linuxgirlie » Wed Jun 08, 2005 10:01 pm
no problem M0PHP.
Karoshi@Home does allow connections from both Linux and Windows PC's.
linuxgirlie
