Booting Linux (PROBLEM)
Postby comcamel » Fri Jun 03, 2005 8:07 am
At school, i am pretty sure that all computers cannot boot from a floppy disk and the cdrom and they have locked the bios, is there anyway or any program that can run in windows which can boot a live cd distro. such as knoppix.
greatful for an answer! COmcamel
comcamel
RE: Booting Linux (PROBLEM)
Postby alloydog » Fri Jun 03, 2005 8:44 am
Look at http://www.linux.org and goto the Distributions page
Under the Catergory menu, you can select Runs on MS Windows.
It found these:
• LoopLinux
• muLinux
• Xteam Linux
• Pklinux
• Tomukas
• TopologiLinux
• Cooperative Linux (aka coLinux)
• Klinux
• AMIGO Linux OS
Brief descriptions, and details where the hom epages are, and where to downlaod are also given. Check it out.
alloydog
Postby Nigel » Fri Jun 03, 2005 1:09 pm
I've used TopologiLinux... it still needs to boot from CD. It uses a big file on your Windows disk instead of a Linux partition, so avoids all the partitioning hassles. It had it's uses... until I discovered Knoppix !
Postby towy71 » Fri Jun 03, 2005 2:15 pm
if I remember rightly zipslack works from a directory in c: under windows
Postby Guest » Wed Jun 08, 2005 7:25 pm
it is actually alright, today i tested out that i can use a floppy, cd drive disabled aswell as booting from memory key, i will create a knoppix boot disc, as described in the manual - and i'll be advertising linux to the class. I might have a go with a harddisk version but knoppix works well thanks!
Postby nelz » Wed Jun 08, 2005 8:18 pm
Put Smart Boot Manager on a floppy and you'll be able to boot any CD.
