Ubuntu! Wow!
Ubuntu! Wow!
Postby logandi » Sat Jun 04, 2005 9:27 pm
I went to the trouble of burning a disc from the DVD to have a look before moving to 64bit gentoo. The installation went fine until the reboot, when it stopped with a grub error. Hurrah for ease-of-use! Now I have a coaster with ubuntu written on it. :roll:
Using the wife's laptop while gentoo compiles for a shiny new amd64...
logandi
Postby 1slipperyfish » Mon Jun 06, 2005 7:54 pm
i have 2 coasters so at least mine make a feature on my pc desk :D i don't see why you have to burn the iso in windows :?:
paul
1slipperyfish
Forum Jester
Postby nelz » Mon Jun 06, 2005 9:27 pm
What makes you think you have to burn the ISO in Windows?
Postby 1slipperyfish » Mon Jun 06, 2005 9:35 pm
because i'm thick?
paul
1slipperyfish
Forum Jester
Postby M0PHP » Mon Jun 06, 2005 11:00 pm
1slipperyfish wrote:because i'm thick?
paul
The most truth you've ever spouted, Paul :lol:
No no Paul, really.. joking aside, nobody is thick (outside the government) - you just need, I don't know ... guidance? :P
M0PHP
Postby towy71 » Mon Jun 06, 2005 11:02 pm
nelz wrote:What makes you think you have to burn the ISO in Windows?
what he said!
in file manager: right click ISO >Actions>Write CD image with k3B....
job done ;-)
this from a point and click expert :lol:
Oh and this was KDE (Kinky Desktop Easy)
Postby Eionmac » Mon Jul 25, 2005 11:55 am
sirs,
20050722
Regretably, I also have Ubunto coasters.
It did not detect my video card (HP form of NVideo G Force 2MX) and came up at a screen resolution that obscured the bottom half of page and would not accept or go to any other resolution. As my (Hewlett Packard) HP Pavilion 1940 is a year 2000 buld I did not think it outdated for Linux.
Knoppix 3.7 and Slax 5 detect and work well.
Regards
eionmac
Eionmac
Postby Nobber » Mon Jul 25, 2005 1:04 pm
I've never been able to get Ubuntu working on my machine either. Strangely, I can't get past the bit where you prepare the partitions on the hard disk, because it refuses to recognise the partitions that are already there, so I can't select the one I want to install on...
I gather some people think the distro is quite spiffy, however.
Nobber
Ubuntu Coasters as well
Postby Snotrag » Thu Aug 11, 2005 8:20 pm
I got farther in my Ubuntu attempt. I used Ultra-ISO to build the image in WS2003, but during the install, the network detection hangs, and interrupts the whole setup routine.
This occurred on two different machines.
- Jason
Snotrag
RE: Ubuntu Coasters as well
Postby A-Wing » Thu Aug 11, 2005 9:23 pm
Are either of you actually able to give us any hardware details so we can diagnose the problems?
If you think the problem is related to te disc you burned have you tried at a lower speed?
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
A-thing
Postby Snotrag » Fri Aug 12, 2005 1:02 am
yes I am perfectly able to divulge, the hardware that exceeds Ubuntu's min. requirements. Home-Built PC, Athlon XP 2600, 1GB PC2700, GeForce FX 5700 256MB, 40GB WD HDD, nForce 2 chip-set. Let the answers flow, please...
- Snotty
Snotrag
RE: A-thing
Postby A-Wing » Fri Aug 12, 2005 6:09 am
It is happening due to a problem talking to your network card or network. Does it unhang after a long period of time (say 10 minutes or so?). I am guessing you are using an onboard nforce2 chip which as far as I am aware has no known problems.
A BIOS update may fix the problem. Or disable the net chip, install, download the updated kernel (which has several net fixes), install it and switch the chip back on.
A-Wing
Thank You
Postby Snotrag » Fri Aug 12, 2005 3:26 pm
I'll try the BIOS update. The Mobo has an integral NIC, and I placed a PCI NIC in for routing. The PC has removable HDD's for separate Windows & Linux.
- Linux is cool, Windows pays the bills.
Jason Watkins
Snotrag
