Open source Rapid Application Development
Goto page 1, 2  Next
AndrewBallantine
PostPosted: Mon Apr 11, 2005 11:22 pm    Post subject: Open source Rapid Application Development Reply with quote
I have, for my sins, been a fairly competent MS Access/SQL 2000 developer for a number of years, but this has been extremely frustrating as you may imagine. However I have managed to build a very comprehensive business system which supports a call centre, sales orders and customer service.
Does anyone have any recommendations for an open source Rapid Application Development tool/framework for developing web applications.
I have looked at Omnis and MTStudio which are both proprietry. I would very much like to use an open source system for an open source project I am considering starting.
There is quite alot of buzz around Ruby and Ruby on Rails, which I am investigating at the moment.
All suggestions welcome.
Andrew Ballantine. Confused
nordle
PostPosted: Thu Apr 14, 2005 11:14 pm    Post subject: RE: Open source Rapid Application Development Reply with quote
I too spend my days infront of EM and QA, hopefully going to switch to postgresql, php and python in the next year or two...lol maybe...
Web application RAD tools, there are of course the usualy suspects from borland, might be worth a look.
This company has done some nice db tools, not to sure on the web front though.
http://www.thekompany.com/home/
There are basic editors / ide's like Quanta (see kde), or bluefish, but they really are for manual coding.
Oracle do a surprising amount, jdeveloper can be used for a lot of stuff, again might be worth a look.
IRC or alt.whatever.newsgroups might specialise a bit more with this, especially as these forums have only bounced back recently so the audience is not that big at the mo.
I think, therefore I compile
purplepangolin
PostPosted: Mon Apr 18, 2005 8:41 pm    Post subject: RE: Open source Rapid Application Development Reply with quote
have a look at the mono project www.go-mono.com. This is an open-source implementation of .Net. Started off by some guys at ximian who were then bought out by Novell so it has solid corporate backing. Also, have a look at the Eclipse project which is a great Java IDE (actually much more than that).
Arion
PostPosted: Sun Apr 24, 2005 7:43 pm    Post subject: RE: Open source Rapid Application Development Reply with quote
I'm not sure, but I think qtdesigner may be free.
It also might be a RAD tool, but I'm not sure since I haven't used it in years, and even then I only used it briefly.
The only other one I can think of at the minute would be Gambas, which is a bit like VB, except uses a more sensable design.
jamiet
PostPosted: Fri May 13, 2005 9:12 am    Post subject: Reply with quote
Check out ATK at www.achievo.org/atk. This isn't a gui RAD but you can get a web based application up and running quite quickly once you understand the framework. By creating a framework which provides all of the coding for presentation layer and logic, it leaves you to concentrate on the business logic. I mentioned it a couple of threads up from this one, so far I am pretty impressed and I am looking forward to coding using this framework.
HTH,
JamieT
youlikeicecream
PostPosted: Sat Jun 04, 2005 9:55 pm    Post subject: Reply with quote
Hi , I am a Delphi programmer and I see that there is kylix for linux. is it any good?
View user's profile Send private message Yahoo Messenger MSN Messenger
skecs
PostPosted: Sun Jun 05, 2005 5:17 am    Post subject: Reply with quote
Have you had a look at the developerWorks from IBM?
The web site is http://www-130.ibm.com/developerworks/
There are Windows & Linux versions available for database and web applications.
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
youlikeicecream
PostPosted: Sun Jun 05, 2005 8:58 am    Post subject: Reply with quote
can anyone recommend a RAD for developing standard apps under linux, I installed Kdevelop, is that gonna do the job ?
Mike Smile
wiz
PostPosted: Sun Jun 05, 2005 10:44 pm    Post subject: Reply with quote
If you come from a Borland Cbuilder/Delphi background you are quickly going to find out just how spoilt (in a nice way) you have been while using these tools.
You can achieve the same things with Linux but, it is done by using a collection of bits & bobs that hang together by a very weak thread.
You can probably design, write & deploy a Delphi database app in less time than it will take you to get one of the Linux database servers up and running.
Practice, practice & more practice is where it's at and it feels like trying to work with one arm missing.
I've used
Kdevelop for c++ coding
QT libraries for database access components
Postgres database
pgsql ? Postgres data table design
All seperate programmes that more or less fit together and allow you to get data into a database. I'm still working on how to get pretty printed reports out though.
wiz
PostPosted: Mon Jun 06, 2005 6:47 am    Post subject: Reply with quote
Try this. I meant to include it in the last post
Lazarus
PostPosted: Mon Jun 06, 2005 12:48 pm    Post subject: Reply with quote
Carn't miss an opportunity to give www.fltk.org a plug. It's about as standard as it gets. But i quite like Athena. Probably more a learning tool, than a work tool though. But, a nice smooth designer, none the less.
Carn't remember reading any comment on "BXPro 6" from lxf33B cd, November 2002 when it was there. One of those expensive environments i think. Still got the disc. I was always meaning to try its' demo out. One never knows (grin)
http://counter.li.org
firefox
PostPosted: Mon Jun 06, 2005 2:10 pm    Post subject: Reply with quote
or just use Kylix, unless you're excluding this because it's not open source?
youlikeicecream
PostPosted: Mon Jun 06, 2005 3:09 pm    Post subject: Reply with quote
not excluding kylix, it just wont f*in run, damn complicated borland products. and. Delphi just gets the job done for windows. Kylix throws up errors saying it can't find or access a shared file.
can paste error message from kylix if it would help.
Mike Smile
youlikeicecream
PostPosted: Mon Jun 06, 2005 3:27 pm    Post subject: Reply with quote
/usr/local/kylix3/bin/delphi: error while loading shared libraries: bpldesignhooks.so.6.9: cannot open shared object file: No such file or directory
Damn - Mike Smile
wiz
PostPosted: Mon Jun 06, 2005 5:49 pm    Post subject: Reply with quote
Here's another one. gambas I haven't looked at it for ages but it seems as though development is still quite brisk.
Goto page 1, 2  Next
Page 1 of 2
