Open source Rapid Application Development
Postby AndrewBallantine » Mon Apr 11, 2005 10:22 pm
I have, for my sins, been a fairly competent MS Access/SQL 2000 developer for a number of years, but this has been extremely frustrating as you may imagine. However I have managed to build a very comprehensive business system which supports a call centre, sales orders and customer service.
Does anyone have any recommendations for an open source Rapid Application Development tool/framework for developing web applications.
I have looked at Omnis and MTStudio which are both proprietry. I would very much like to use an open source system for an open source project I am considering starting.
There is quite alot of buzz around Ruby and Ruby on Rails, which I am investigating at the moment.
All suggestions welcome.
Andrew Ballantine. :?
AndrewBallantine
RE: Open source Rapid Application Development
Postby nordle » Thu Apr 14, 2005 10:14 pm
I too spend my days infront of EM and QA, hopefully going to switch to postgresql, php and python in the next year or two...lol maybe...
Web application RAD tools, there are of course the usualy suspects from borland, might be worth a look.
This company has done some nice db tools, not to sure on the web front though.
http://www.thekompany.com/home/
There are basic editors / ide's like Quanta (see kde), or bluefish, but they really are for manual coding.
Oracle do a surprising amount, jdeveloper can be used for a lot of stuff, again might be worth a look.
IRC or alt.whatever.newsgroups might specialise a bit more with this, especially as these forums have only bounced back recently so the audience is not that big at the mo.
I think, therefore I compile
nordle
Postby purplepangolin » Mon Apr 18, 2005 7:41 pm
have a look at the mono project www.go-mono.com. This is an open-source implementation of .Net. Started off by some guys at ximian who were then bought out by Novell so it has solid corporate backing. Also, have a look at the Eclipse project which is a great Java IDE (actually much more than that).
purplepangolin
Postby Arion » Sun Apr 24, 2005 6:43 pm
I'm not sure, but I think qtdesigner may be free.
It also might be a RAD tool, but I'm not sure since I haven't used it in years, and even then I only used it briefly.
The only other one I can think of at the minute would be Gambas, which is a bit like VB, except uses a more sensable design.
Arion
Postby jamiet » Fri May 13, 2005 8:12 am
Check out ATK at http://www.achievo.org/atk. This isn't a gui RAD but you can get a web based application up and running quite quickly once you understand the framework. By creating a framework which provides all of the coding for presentation layer and logic, it leaves you to concentrate on the business logic. I mentioned it a couple of threads up from this one, so far I am pretty impressed and I am looking forward to coding using this framework.
HTH,
JamieT
jamiet
Postby youlikeicecream » Sat Jun 04, 2005 8:55 pm
Hi , I am a Delphi programmer and I see that there is kylix for linux. is it any good?
youlikeicecream
Postby skecs » Sun Jun 05, 2005 4:17 am
Have you had a look at the developerWorks from IBM?
The web site is http://www-130.ibm.com/developerworks/
There are Windows & Linux versions available for database and web applications.
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
Postby youlikeicecream » Sun Jun 05, 2005 7:58 am
can anyone recommend a RAD for developing standard apps under linux, I installed Kdevelop, is that gonna do the job ?
Mike :)
youlikeicecream
Postby wiz » Sun Jun 05, 2005 9:44 pm
If you come from a Borland Cbuilder/Delphi background you are quickly going to find out just how spoilt (in a nice way) you have been while using these tools.
You can achieve the same things with Linux but, it is done by using a collection of bits & bobs that hang together by a very weak thread.
You can probably design, write & deploy a Delphi database app in less time than it will take you to get one of the Linux database servers up and running.
Practice, practice & more practice is where it's at and it feels like trying to work with one arm missing.
I've used
Kdevelop for c++ coding
QT libraries for database access components
Postgres database
pgsql ? Postgres data table design
All seperate programmes that more or less fit together and allow you to get data into a database. I'm still working on how to get pretty printed reports out though.
wiz
Postby wiz » Mon Jun 06, 2005 5:47 am
Try this. I meant to include it in the last post
Lazarus
wiz
Postby jjmac » Mon Jun 06, 2005 11:48 am
Carn't miss an opportunity to give www.fltk.org a plug. It's about as standard as it gets. But i quite like Athena. Probably more a learning tool, than a work tool though. But, a nice smooth designer, none the less.
Carn't remember reading any comment on "BXPro 6" from lxf33B cd, November 2002 when it was there. One of those expensive environments i think. Still got the disc. I was always meaning to try its' demo out. One never knows (grin)
http://counter.li.org
Postby firefox » Mon Jun 06, 2005 1:10 pm
wiz wrote:If you come from a Borland Cbuilder/Delphi background you are quickly going to find out just how spoilt (in a nice way) you have been while using these tools.
or just use Kylix, unless you're excluding this because it's not open source?
firefox
Postby youlikeicecream » Mon Jun 06, 2005 2:09 pm
not excluding kylix, it just wont f*in run, damn complicated borland products. and. Delphi just gets the job done for windows. Kylix throws up errors saying it can't find or access a shared file.
can paste error message from kylix if it would help.
Mike :)
youlikeicecream
Postby youlikeicecream » Mon Jun 06, 2005 2:27 pm
/usr/local/kylix3/bin/delphi: error while loading shared libraries: bpldesignhooks.so.6.9: cannot open shared object file: No such file or directory
Damn - Mike :)
youlikeicecream
Postby wiz » Mon Jun 06, 2005 4:49 pm
Here's another one. gambas I haven't looked at it for ages but it seems as though development is still quite brisk.
wiz
