New Release of <oXygen/> XML Editor
Postby syncrosoft » Wed Jun 14, 2006 3:17 pm
Syncro Soft Ltd, the producer of <oXygen/> XML Editor, has announced the immediate availability of version 7.2 of its XML Editor, Schema Editor and XSLT/XQuery Debugger.
Version 7.2 of the <oXygen/> XML Editor adds as main features a complete Subversion client, support for flattening XML Schemata, an XML Schema instance generator, integration with the X-Hive/DB, MarkLogic and TigerLogic XML databases, editing actions on the diagram, rename refactoring action and search references/declarations actions in XML Schema and Relax NG schemata editors.
For the complete list of new features please visit
New in version 7.2:
<oXygen/> makes easier the document sharing between content authors by including a Subversion (SVN) client. The SVN client allows you to browse repositories, check for changes, review, merge and commit changes, update your working copy and examine the revision history.
Schema support enhancements include support for flattening XML Schema, rename refactoring action, find declarations or references of XML Schema components. There are available new editing actions in the contextual menu of the full model diagram view allowing the addition of new elements and editing their attributes. A new regular expressions builder has been added that helps to construct and test regular expressions allowed in XML Schema restriction patterns. You can now quickly generate a large set of XML document samples based on a given XML Schema using the XML Schema instance generator tool.
The HTML documentation for XML Schema has been improved. The generated schema diagram images contain image maps allowing to click directly on a diagram component to navigate to the documentation for that component. The documentation of a definition includes an "Used By" section with links to the other definitions which refer to it. Navigation is possible in both directions between a schema and the included/imported ones.
The support for XQuery execution over an XML native database was extended by adding the following engines: X-Hive/DB XML Database, MarkLogic XML Database and TigerLogic XML Database. With the integrated xqDoc tool you can generate HTML documentation for XQuery files with just a couple of clicks. One or more input XQuery files are accepted and the function namespaces are configurable.
Other new features include the possibility to generate a brief documentation listing the services, bindings, port types and messages defined in a WSDL file, the addition of a dockable view called Dynamic Help that changes its content automatically to the relevant help page for the focused editor, view or dialog and support to configure the background color for syntax highlighting tokens.
Pricing and Availability
<oXygen/> XML Editor and XSLT Debugger is available immediately in two editions:
Multi-platform Academic/Non-profit license costs USD 48.00
Multi-platform Professional license costs USD 180.00.
To purchase please visit the <oXygen/> XML Editor store at
<oXygen/> 7.2 can be freely evaluated for 30 days from and it is available as a free upgrade for all oXygen version 7 users.
<oXygen/> is a registered trademark of Syncro Soft in the U.S and other countries. Any other trademarks or service marks contained herein are the property of their respective owners.
SOURCE: Syncro Soft Ltd.
Return to Announcements
