guy LXF regular
Joined: Thu Apr 07, 2005 1:07 pm Posts: 860 Location: Worcestershire
Posted: Mon Jun 05, 2006 12:23 pm Post subject: Help: FTP client for Windows |
I need to be able to change file and directory permisions on a Linux web server, using an FTP client on a Windows 98 box - hence this is a Windows question.
WS FTP Pro is pay-for.
I have been using CoreFTP, which is supposed to do this but that bit of the Help has not been writtemn yet and I can't figure it from scratch.
Does anybody know a free FTP client that does this, or how to do it in Core FTP? _________________ Cheers,
Guy
The eternal help vampire |
M0PHP LXF regular
Joined: Wed Apr 06, 2005 8:40 am Posts: 737 Location: Bishop Auckland, County Durham, UK
Posted: Mon Jun 05, 2006 12:26 pm Post subject: RE: Help: FTP client for Windows |
FileZilla _________________
TheDoctor LXF regular
Posted: Mon Jun 05, 2006 12:42 pm Post subject: |
I use SmartFTP.
To change permissions, right click on the folder/file and select properties. You can also chmod the same way. |
guy LXF regular
Posted: Tue Jun 06, 2006 2:12 pm Post subject: |
Thanks folks. FileZilla needs 32-bit Windows, so I'll try Smart FTP and hopefully report back. _________________ Cheers,
Guy
Hello LXF regular
Posted: Wed Jun 07, 2006 8:38 pm Post subject: |
| A lot of people say flash fxp but I have used smartftp in the past and its worked fine. |
marco LXF regular
Joined: Fri Sep 30, 2005 12:17 pm Posts: 121 Location: London, UK
Posted: Fri Jun 30, 2006 10:51 am Post subject: |
| TheDoctor wrote: | I use SmartFTP.
I use SmartFTP as well. It's a pretty good tool. I can highly recommend it. |
