Best Linux Internal Modem
Postby bibstha » Sun May 29, 2005 9:39 am
I have this motorola modem
which although i tried its driver fromthe website couldn't get running
so,i was thinking of buying a new internal modem,
any suggestions?? which internal modem works good on
RED HAT.
i have red hat 9 installed in my pc
bibstha
RE: Best Linux Internal Modem
Postby Guest » Mon May 30, 2005 10:50 am
www.linmodems.org should give you a pointer as to which internal modems might work. Best approach, however, is to use an external serial(RS-232) modem. You should be able to pick up a second-hand one for £10 or a new one for about £20-£40.
Regards,
Zeno
Postby dandnsmith » Tue May 31, 2005 6:59 am
I'd support the external modem choice for RH9 - later releases of linux stuff may well be better, but internal modems which are likely to be 'winmodems' can give a lot of trouble.
Derek
dandnsmith
Postby Nobber » Tue May 31, 2005 1:48 pm
Real internal (PCI) modems that need no special driver can be found if you look hard enough, though they tend to be much more expensive than softmodems. For years I used one made by Multitech. It cost about £100, but worked a treat.
Nobber
Users browsing this forum: catgate and 0 guests
