Win 2k and wireless
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS
Hello
PostPosted: Wed May 24, 2006 5:49 pm    Post subject: Win 2k and wireless Reply with quote
I need to get some laptops running wirelessly with Win 2k however after reading some websites people say wireless is only any good with xp.
Is this true or just ms trying to get me to upgrade?
I would use Linux if I could but it has to be 2k Sad + I havent worked out how to get Linux and wireless going yet
PostPosted: Wed May 24, 2006 5:52 pm    Post subject: RE: Win 2k and wireless Reply with quote
Win2k is fine with wireless my belkin pcmcia card is listed as working for win98 upwards
Hello
PostPosted: Wed May 24, 2006 6:13 pm    Post subject: Reply with quote
Im not sure I would trust win 98 with wireless however I think 2k should do the job all it seems to be missing is the wireless setup wizard. All my wireless experiance has been the odd bit so I am not too up with it
PostPosted: Wed May 24, 2006 8:52 pm    Post subject: Reply with quote
We have a Win2k laptop at work that runs a 3Com wireless card with no problems... we use the 3Com software to manage connections.
TheDoctor
PostPosted: Wed May 24, 2006 9:19 pm    Post subject: Reply with quote
I run a win98SE PC connected via wireless. In fact, I have to connect it to my router via wireless because of certain hardware constraints (ie there's a hole where my ethernet connection should be Smile ). I don't have any problem (other than the problems I have running the machine standalone, that is).
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS All times are GMT
