Laptop Batteries
Laptop Batteries
Postby tommohawk » Tue May 16, 2006 8:28 pm
Why is it that my laptop battery lasts about twice as long under Linux than under Windows?
It's not that I am looking for answers, its just I am a bit curious? Is Linux really that that much more efficient (in terms of processor usage etc) that it just uses fewer system resources and hence less power?
Well, maybe not twice as long but certainly significantly longer!
It's not that some people have willpower and some don't. It's that some people are ready to change and others are not.
Registered Linux User 420262
Registered Ubuntu User 19060
tommohawk
RE: Laptop Batteries
Postby shifty_ben » Tue May 23, 2006 12:24 am
Alternatively it could just be that Linux warns you of a low battery later than Windows. I noticed the same thing when i first got my laptop, though I couldn't say how big the gap is as I havent had Windows on here in a long time, something that I am incredibly pleased about :D
shifty_ben
Postby M-Saunders » Tue May 23, 2006 9:14 am
It could be using different power-saving schemes to Windows. When I installed Ubuntu on my new laptop, it defaulted to spinning down the hard drive after 5 seconds of inactivity! A bit aggressive methinks -- and also very annoying. Every time I did something that touched the disc, it'd take a few seconds to spin up. Sorted that out with hdparm -S :-)
M
M-Saunders
Postby roeleboel » Tue May 23, 2006 3:57 pm
Mike,
that hdparm -S thing, do you set that like this:
sudo hdparm -S=241 hda (for 1/2 hour waiting)? The man page is not very clear about this.
regards
Roel
Kororaa on a Acer Aspire 1360 Laptop
Belgium
roeleboel
Postby roeleboel » Tue May 23, 2006 4:00 pm
Already found it:
sudo hdparm -S 241 /dev/hda ;)
Belgium
roeleboel
Users browsing this forum: Exabot [Bot] and 2 guests
