Website incompatible with a Linux browser
Postby GeoNorth » Tue May 16, 2006 12:40 am
I can't log in using Konqueror 3.4.3
Whenever I try it just sends me loops over with the warning that the data will be resubmitted... over and over again.
Yeah, it doesn't hurt to have Firefox as well, but let's not make Firefox the IE of Linux, eh?
GeoNorth
RE: Website incompatible with a Linux browser
Postby nelz » Tue May 16, 2006 9:03 am
I've been using Konqueror with this site since before it was launched, which would have been around Konqueror 3.4.1 or 3.4.2 (I never used 3.4.3). There were some speed issues very early on, but never a login problem. Unless this is something peculiar to 3.4.3, which is highly unlikely as no one else has reported it, I suspect the problem lies either i your Konqueror config or some weird proxy behaviour at your ISP.
Try creating a new user in KDE then using Konqueror as that user to log in. This will have the effect of resetting everything to the defaults.
Postby MartyBartfast » Tue May 16, 2006 6:48 pm
FWIW I'm posting this from Konqueror 3.4.3, no probs at all, so looks like it's your settings.
MartyBartfast
Re: Website incompatible with a Linux browser
Postby TheDoctor » Tue May 16, 2006 10:23 pm
GeoNorth wrote:I can't log in using Konqueror 3.4.3
I had this problem a couple of months ago. It's because you're not accepting cookies from the site. Fix that and all will be well, I'll wager.
TheDoctor
Postby GeoNorth » Thu May 25, 2006 9:59 am
That's not the problem at all, Konqueror is set to accept cookies, the only setting I can change is to accept cookies only from the originating server.
I changed that and set my cookie policy to "ask" only difference was it asked me to accept 2 cookies from advertsiing.com. I accepted the cookies and still get the looping problem.
EDIT: right, turns out if I leave the site and come back again or manually type in the homepage I'm logged in and able to post under Konq. A minor niggle but still something I don't have to do under Firefox :P I think it might be worth fixing, but you may disagree :D
GeoNorth
RE: Re: Website incompatible with a Linux browser
Postby nelz » Thu May 25, 2006 10:20 am
It is worth fixing, but the problem apparently lies at your end, as no one else is experiencing this. I still think you should try with a new user, so KDE is running everything at the default settings.
Return to This Website
Users browsing this forum: Bing [Bot] and 0 guests
