wiz LXF regular
Joined: Thu Apr 07, 2005 7:20 pm Posts: 119 Location: In front of a computer
Posted: Mon May 09, 2005 6:03 pm Post subject: RSI problems |
| Has anybody had a problem with Repetetive strain injury? I have just finished a code bashing session and I was getting concerned because my right hand was starting to sieze up ( No sniggering at the back!) and I started thinking that I would not be able to finish my customers job on time. I have not had this before in 23 years of key bashing and I don't want it again. Do the fancy keyboards help? Does anything help? |
M0PHP LXF regular
Joined: Wed Apr 06, 2005 8:40 am Posts: 737 Location: Bishop Auckland, County Durham, UK
Posted: Mon May 09, 2005 6:30 pm Post subject: |
After several hours of solid coding I sometimes get a pain in the top of my shoulder and sometimes in the wrist which I put down to RSI. I just remind myself to take a longer break. Must also get some to give me a massage  |
1slipperyfish Forum Jester
Posted: Mon May 09, 2005 6:47 pm Post subject: |
or a rubdown with codliver oil?
paul _________________ i am a follower of the culture
wiz LXF regular
Posted: Mon May 09, 2005 6:53 pm Post subject: |
As long as it's not from you!
There, I've started you off on the right track already. |
davecs LXF regular
Joined: Sun Apr 10, 2005 12:13 am Posts: 530 Location: Dagenham, Essex
Posted: Mon May 09, 2005 7:24 pm Post subject: |
There are many forms of RSI, from some which do permanent damage to some relatively minor inflammations. The best cure for the minor inflammation is to take your breaks, and some aspirin. If that doesn't work, see your doctor because you might have trouble. _________________
Asus Asus M2N32 WS Pro+Athlon AM2/4200+ — GeForce 7600GT — 2Gb Cosair VS RAM — 500Gb WD5000AAKS SATA Drive — PCLinuxOS |
Nigel LXF regular
Posted: Mon May 09, 2005 7:45 pm Post subject: |
After many years of programming I was starting to get the occasional twinge in my wrists - three things have helped keep that at bay :
1. A Microsoft Natural keyboard. They take a few days to get used to, but for heavy typing work I don't want to use anything else now - it's so much kinder on the wrists. I know it kind of goes against the grain to use MS anything, but I've found that their hardware (keyboards, mice etc) is generally rather good.
2. An optical wheel mouse. Especially when using a graphical IDE.
3. A gel-filled support for my mouse wrist. Gel-eez make good ones.
But anything's better than the keyboards you used to get with Norsk Data terminals
 _________________ Hope this helps,
Nigel. |
wiz LXF regular
Posted: Mon May 09, 2005 7:52 pm Post subject: |
| I ought to add that I have now compounded the problem with stupidity by using a power drill at home. I couldn't hold it properly and it twisted out of my hand and the handle whacked me on the wrist. It appears that the biggest problem is with my brain functions. |
pixel8ed
Posted: Mon May 09, 2005 9:01 pm Post subject: |
| Like you, I started getting RSI symptoms within the last 12 months after >20years of trouble free computer use. Most of it is in my mouse hand so... lessen mouse use (more keyboard shortcuts), take more breaks, adjust at your seated posture. Buying an LCD monitor (so I wasn't squinting or hunching so much) and changing my work seating helped me. Lessening my computer time (ie in my own time) helps a lot too when I feel it coming on. |
nordle LXF regular
Posted: Mon May 09, 2005 11:18 pm Post subject: |
The cod liver oil idea could be a good one, not the massage, but just the supplements. I had a project last year and was typing for 7-10 hours with a 1 hour break, after 2 months my tendons around my knuckles were inflamed, making typing VERY painful.
This year, a new project, but this time I had been taking cod liver capsules a month before starting and changed keyboard to a flat one with laptop type keys and a gell wrist pad mouse mat:
http://tinyurl.com/a4mtf (cod liver capsules 1000mg)
http://tinyurl.com/dgfr9 (logitich ultrax keyboard)
http://tinyurl.com/drdtu (mouse mat)
No problems this time round. _________________ I think, therefore I compile |
jjmac LXF regular
Posted: Tue May 24, 2005 11:39 am Post subject: |
Yes, or so i think. It can be dealt with in various ways. Basically by breaking up your sessions and getting the blood to circulate is a good idea. Moving around, stretching, light exercise. walking etc.
The optical mouse point is a good idea too, along with ergonomics/posture awareness..
The problem with that stuff is the way it can creep up on you over time. And the eyes too .... screens can stuff em around as well.
| Code: |
-:- If the system is the answer, then the question
must have been really stupid -:-
_________________ http://counter.li.org
wiz LXF regular
Posted: Tue May 24, 2005 5:56 pm Post subject: |
I think I got a wake up call about working to such a tight deadline that I grafted at the keyboard far longer than I would otherwise have done.
From now on I'm working sensible hours with proper breaks and hopefully I'll get back to normal. ( Normal being middle aged with a creaky knee, deteriorating eyesight, damaged wrist & various other faulty parts ) |
Marrea LXF regular
Joined: Fri Apr 08, 2005 10:32 pm Posts: 1846 Location: Chilterns, West Hertfordshire
Posted: Sun Jun 12, 2005 3:42 pm Post subject: |
Interesting reading through this. I am a secretary and have been bashing away at keyboards for just over 38 years now, with no adverse effects at all from the physical action of typing. Until, until ... I started doing digital imaging using Photoshop LE several years ago and was spending long periods holding down the mouse button while doing selections. I didn't suffer any pain but developed a small ganglion on my right upper wrist, which almost certainly was caused by the pressure involved in holding down the button and moving the mouse around at the same time.
I thought, this is not good. So I went out and bought a Wacom tablet and pen and have been using that ever since whenever I want to do some "Photoshopping". The ganglion disappeared and has not reappeared.
How do you guys usually type? Do you touch type (as opposed to "two finger" typing)? Do you have your hands gently hovering over the keys so that your wrists and forearms follow a more or less straight line (ie like a piano player)? Or do you rest your wrists on the desk while you're typing, thus producing more of an angle between wrist and forearm? This latter method I believe can cause considerable strain over time. And with modern computer keyboards, you only need to press the keys very gently - no need to hammer them like you had to on the old "sit up and beg" manual typewriters I used when I first started work !! |
M0PHP LXF regular
Posted: Sun Jun 12, 2005 4:59 pm Post subject: |
Firefox gives me RSI.. I use my little finger and middle finger for the Ctrl+Tab combination (probably completely wrong fingers) but it's been so convenient and I've gotten used to it now  |
Nigel LXF regular
Posted: Sun Jun 12, 2005 5:02 pm Post subject: |
I don't touch type, but I do use more than two fingers (three on one hand and two on the other normally, with the right thumb for the space bar & the left little finger for the shift key). I don't need to look down at the keys too often these days.
I do tend to rest my palms on the built-in wrist rest on my MS natural keyboard, or on the flat area in front of the keyboard on my laptop. Either is better than resting them on the desk, although I know I really ought to have them hovering above the keyboard like a proper typist.
Probably the worst typing position I have used was 20+ years ago when using VT100 terminals for programming - the keyboard connected to the vdu by means of a long curly cord, and we found you could lean back in the chair with your feet on the desk alongside the screen and the keyboard in your lap whilst programming... which, of course, we all did whenever the boss wasn't around. Green screens, flourescent lighting, no windows - too many years of that is why I now wear glasses!
I know what you mean about holding the mouse button down for extended periods - that's why I insist on wheel-mice these days (I found myself doing it whilst scrolling through long documents or web pages). I've used a Wacom tablet - they're great for any type of drawing/painting work, but I find them unnatural for anything involving lots of clicking. It's probably just me...  _________________ Hope this helps,
Nigel. |
Marrea LXF regular
Posted: Sun Jun 12, 2005 7:03 pm Post subject: |
| Nigel wrote: | | Green screens, flourescent lighting, no windows - too many years of that is why I now wear glasses! |
Yup, I'm quite convinced it was constantly staring at computer screens day in, day out, which accelerated my need to wear glasses.
And I often wonder what all this thumb pressing on mobile phones is doing to people's hands.
We can't seem to do without modern technology but it does have its downsides unfortunately. |
