Mandriva LE2005 update source
Postby guest » Sat May 21, 2005 9:49 am
Following installation of Mandriva from the mag DVD, Ive set up my update source using one of the UK URLs returned by Add Update Source from the Configure Media GUI. But to date no updates have been reported. This surprises me. With Mandrake 10.x I was always installing security updates. Am I doing something wrong. The source I chose is
http://www.sunsite.org.uk/package/mandr ... in_updates
guest
RE: Mandriva LE2005 update source
Postby fairless » Sat May 21, 2005 12:44 pm
Here's the entries in my /etc/urpmi/urpmi.cfg file. They seem to work but using urpmi did not seem to pull everything back, whereas "Mandrake Linuxupdate" did:
Installation\ CD\ 1\ (cdrom1) removable://mnt/cdrom/media/main {
hdlist: hdlist.Installation CD 1 (cdrom1).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist1.cz
Installation\ CD\ 2\ (cdrom2) removable://mnt/cdrom/media/main2 {
hdlist: hdlist.Installation CD 2 (cdrom2).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist2.cz
Installation\ CD\ 3\ (cdrom3) removable://mnt/cdrom/media/main3 {
hdlist: hdlist.Installation CD 3 (cdrom3).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist3.cz
Installation\ CD\ 4\ (cdrom4) removable://mnt/cdrom/media/main4 {
hdlist: hdlist.Installation CD 4 (cdrom4).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist4.cz
Installation\ CD\ 4\ (cdrom5) removable://mnt/cdrom/media/commercial {
hdlist: hdlist.Installation CD 4 (cdrom5).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist5.cz
Installation\ CD\ 4\ (cdrom6) removable://mnt/cdrom/media/drivers {
hdlist: hdlist.Installation CD 4 (cdrom6).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist6.cz
Installation\ CD\ 4\ (cdrom7) removable://mnt/cdrom/media/dkms {
hdlist: hdlist.Installation CD 4 (cdrom7).cz
key-ids: 70771ff3
removable: /dev/hda
with_hdlist: ../../media/media_info/hdlist7.cz
update_source http://anorien.csc.warwick.ac.uk/mirror ... in_updates {
hdlist: hdlist.update_source.cz
key-ids: 22458a98
list: list.update_source
update
with_hdlist: media_info/hdlist.cz
updates ftp://anorien.csc.warwick.ac.uk/Mandrak ... in_updates {
hdlist: hdlist.updates.cz
key-ids: 22458a98
list: list.updates
update
main ftp://anorien.csc.warwick.ac.uk/Mandrak ... media/main {
hdlist: hdlist.main.cz
contrib ftp://anorien.csc.warwick.ac.uk/Mandrak ... ia/contrib {
hdlist: hdlist.contrib.cz
plf-free ftp://ftp.easynet.fr/plf/mandrake/free/10.2 {
hdlist: hdlist.plf-free.cz
key-ids: caba22ae
list: list.plf-free
with_hdlist: hdlist.cz
plf-nonfree ftp://ftp.easynet.fr/plf/mandrake/non-free/10.2 {
hdlist: hdlist.plf-nonfree.cz
key-ids: caba22ae
list: list.plf-nonfree
Hope this helps, Neil
fairless
Postby Guest » Sat May 21, 2005 1:33 pm
Thanks Neil, I'll compare that with mine.
Postby fairless » Sat May 21, 2005 2:53 pm
You'll need to modify those entries for x86_64 if you're running on 32bit.
fairless
Postby firefox » Mon May 23, 2005 9:34 am
You should try Easy Urpmi, it's very good!
firefox
Postby Guest » Tue May 24, 2005 8:41 pm
[quote="firefox"]You should try Easy Urpmi, itI see what you mean. Thanks for the tip. You'd think that the mirrors offered by the built-in tool would all be OK though.
Anyway all's fine now after 430Mb of updates.
Thankyou all for the help.
