Connecting to an NSLU2 from the internet.
Postby itx-weather » Sun May 22, 2005 12:09 am
Can anyone advise how to go about connecting to a Linksys NSLU2 from the internet. This is by all accounts a feature of an NSLU2 but i've not been successful in finding documentation on this.
Thank you in advance for any suggestions.
Best Regards.
itx-weather
RE: Connecting to an NSLU2 from the internet.
Postby MOR » Mon May 30, 2005 10:31 pm
As far as I know this is a feature that would have to be supported by your router / modem that the NSLU2 is connected to. This can be done with port forwarding if supported. You should also be able to connect via a VPN. If you use the unslung config then you can set the NSLU up as a simple webserver.
MOR
