Outputting group members
Postby shifty_ben » Thu Apr 06, 2006 12:37 pm
Hi all,
Im currently writing a CLI frontend to manage my webserver, it has a few users on it that are all members of the group webhosting. What I seem to have come stuck on is building an offline 'database' of this, the reason database is in apostraphies is because it will jsut be a text file with the relevant details in.
I can't seem to find any way of running a command that will output all the users in a specific group, in this case webhosting.
Im using BASH for the rest of the frontend but if any suggestions are in other languages then I should be able to incorporate that.
Any ideas?
cheers
Ben
shifty_ben
RE: Outputting group members
Postby nelz » Thu Apr 06, 2006 1:34 pm
If they are members of webhosting ass a secondary group, you can grep this information from /etc/group
grep ^${GROUP} /etc/group | cut -d: -f4
To find those that are members of the group as their primary group, you'd have to convert the group name to a numeric ID then grep /etc/passwd.
GID=$(grep ^${GROUP} /etc/group | cut -d: -f3)
egrep ".*?:.*?:.*?:${GID}:.*" /etc/passwd | cut -d: -f1
should do it, although some error checking might be a good idea.
Postby shifty_ben » Thu Apr 06, 2006 2:01 pm
Excellent Thank you :D just what I was needing, they are all in there as a secondary group so that makes life much easier :D
shifty_ben
