pclinux login problem?
Postby 1slipperyfish » Thu May 19, 2005 8:44 pm
i have a "friend" who was using pclinux live but didn't install it but forgot to take note of the passwords for root and guest :? then installed the mandriva distro(mistake nowhere near as good)
is there any way to reset the passwords if you go into console login?
thanks for your time
paul
1slipperyfish
Forum Jester
RE: pclinux login problem?
Postby Guest » Thu May 19, 2005 10:36 pm
Hi
The passwords for PCLinuxOS are:
Guest = guest
Root = root
I hope the helps.
Regards jim
Postby 1slipperyfish » Fri May 20, 2005 8:04 am
thanks a lot for that i got all in a muddle :D
is that your password as it's your name or is it for everyone? :D
paul
1slipperyfish
Forum Jester
Postby Guest » Fri May 20, 2005 10:24 am
Hi
To log in as Guest click on Guest in the login manager, then type guest in the password space.
Good Luck.
Jim
Postby 1slipperyfish » Fri May 20, 2005 10:36 am
thakns jim :D
i was just being daft rather than stupid :roll: (it can be difficult to tell)
paul
1slipperyfish
Forum Jester
Postby davecs » Mon May 23, 2005 9:54 am
You can of course change both passwords if you install it!
davecs
Postby 1slipperyfish » Mon May 23, 2005 4:07 pm
thanks davecs but i'm having enough trouble getting my modem set up in mandriva at the minute :roll:
paul
1slipperyfish
Forum Jester
