KDE 3.5.2
KDE 3.5.2
Postby Rhakios » Tue Mar 28, 2006 5:26 pm
The next bug fix release is out, announcement is here.
I see that the main SuSE ftp site has new packages already, I assume that the mirrors will be synced by tomorrow, with minor package updates over the next few weeks (judging by past experience).
RE: KDE 3.5.2
Postby Nobber » Wed Mar 29, 2006 1:07 pm
And presumably Konqueror's still only half-usable unless you have icon view on by default? :cry:
Nobber
RE: KDE 3.5.2
Postby nelz » Wed Mar 29, 2006 2:38 pm
There does still seem to be a tendency for the filemanager view to revert to icons, but only on removable devices using a system:/ URI. Remove the system: part and it holds it's mode. This would appear to be a kioslave bug rather than a fault of Konqueror, and certainly removes a lot less than 50% of its usability :)
RE: KDE 3.5.2
Postby Rhakios » Wed Mar 29, 2006 6:30 pm
I happen to like icon view :P
RE: KDE 3.5.2
Postby nelz » Wed Mar 29, 2006 9:14 pm
I've noticed another bug/feature with this. When viewing a directory of images in icon view via a system:/ URI, no image previews are shown. Delete the system: part and Konqueror starts showing previews.
Postby Hello » Fri Mar 31, 2006 6:20 pm
Will this update come through yast (Im still not sure quite how many packages it does update)
Hello
Postby Rhakios » Fri Mar 31, 2006 6:25 pm
Only if you add the correct repositories to your configuration.
I have it installed now, seems one fine, even one new feature, or at least one I have not seen before.
Postby Hello » Fri Mar 31, 2006 6:29 pm
Rhakios wrote:Only if you add the correct repositories to your configuration.
Sorry but what is one of them
Hello
Postby Rhakios » Fri Mar 31, 2006 7:01 pm
A repository is a location, usually on an ftp server, but it could be http, where software packages are stored along with files that enable you to integrate the repository as a software resource for downloading and installation, with automatic resolution of dependencies (where possible).
How do you do that? Would probably be your next question. This has been dealt with quite a number of times before on these forums and you could do a search, or just look here.
Postby davecs » Fri Mar 31, 2006 8:29 pm
Texstar had KDE3.5.2 in PCLinuxOS unstable before its official release, and moved the builds to the public servers on the day of the release.
KDE3.5.2 seems to have cured a bug in PCLOS re KDE Screensavers. The KDE Dictionary panel applet deals with narrow panels better, it seems a bit snappier. No complaints at all from me!
davecs
Return to Announcements
