gfhgfh
Postby lxfadmin » Tue May 17, 2005 1:34 pm
Guest posting is allowed only in the Help forum. The feeling was that if you were looking for help, you might not be on your usual computer, or it may not be working properly etc. Also, we always find it a bit annoying that you have to register on sites to post a simple message.
As for Mr ffgfgfg, we have taken steps to stop any reposting. As with the old site, we won't be discussing what these actually are. But he's the only one causing a problem, so it isn't worth getting upset about.
lxfadmin
Postby Guest » Tue May 17, 2005 5:07 pm
On some other Future forums you can't even VIEW the forums without logging in.
Postby Guest » Tue May 17, 2005 5:08 pm
Plus forcing people to log in will stop accidental guest posting
Doctor Flange
that was me above
Postby Ram » Tue May 17, 2005 8:40 pm
I have to login everytime with this box it just not remembering the settings.
I've just update FF to 1.03 lets see if that helps.
Cookies are OK just this site I have a problem with.
Postby Ram » Tue May 17, 2005 8:41 pm
My point exactly.
Postby Nigel » Wed May 18, 2005 8:30 am
Anonymous wrote:On some other Future forums you can't even VIEW the forums without logging in.
That's just irritating. I wouldn't want to see LXF go that far.
