Modem Connection
Modem Connection
Postby acraigon » Mon May 16, 2005 9:31 am
I am having a little difficulty getting my serial modem working with Mandriva 2005 and Suse 9.2.. Modem attached to /dev/ttsy0. The modem dials out and connects and waits for a prompt.
Serial onection established
renamed interface ppp0 to modem0
using interface modem0
modem hangup
connection terminated
terminated signal 15
Anyone got any ideas what I am doing wrong?
acraigon
RE: Modem Connection
Postby Rhakios » Mon May 16, 2005 6:21 pm
With SuSE 9.2, have you enabled stupid mode - that's not an insult, it's an option in YaST's set up, when you get to the Connection Parameters section. Spontaneous hang-ups are a symptom of not using it.
Postby sirrondach » Mon May 16, 2005 9:06 pm
I'm not too sure exactly where your modem connection is falling over, but are you using kppp as the dialler? If so, before clicking on connect, click on configure then modems then device and set modem device to /dev/tty0 instead of /dev/modem0 if that is what is there now.
Another cause of unexpected terminations like yours is the handshaking (authentication) protocol you have set for your ISP connection. Make sure this is corectly set for your particular ISp - usually PAP/CHAP will do but some require a login script to be run.
sirrondach
