Wireless Network card (ACX100,ACX111, PrismGT) where to buy?
Postby Xraynorm » Thu Feb 16, 2006 8:15 pm
Hello.
Could someone recommend a wireless PCI network card for SUSE 10?
YAST online update has firmware for ACX100,ACX111, PrismGT WLAN cards.
Where can I buy these cards?
How well do they work?
Thanks.[/list] :?
Xraynorm
RE: Wireless Network card (ACX100,ACX111, PrismGT) where to
Postby duff » Mon Feb 20, 2006 12:34 pm
I use a Belkin F5D 6020 ver 2 card in my laptop with Suse 10. Works great. It uses the atmel chipset drivers for which are included with suse (under the "Hardware -> Other" software group in YAST... I think). It's an 11.b card so might be harder to find - everything seems to be 11.g now! Hey ho!
Cheers
duff
duff
Postby Rhakios » Mon Feb 20, 2006 7:34 pm
In the UK you could get one from here. Though you may well find it cheaper elsewhere.
Postby Xraynorm » Tue Apr 18, 2006 8:40 am
Thanks for you help.
Found one on ebay, it works fine!! :)
Xraynorm
