editing text files from within the shell
snuffsaid
PostPosted: Mon Feb 06, 2006 10:48 pm    Post subject: editing text files from within the shell Reply with quote
evening all,
I have been trying to get a shell script working that will automatically edit a text file. The text file is set out using ':' as a delimiter between bits of info, a bit like the /etc/passwd file. I am trying to use only bash shell scripting for this, no PHP, Ruby, PERL, etc. for reasons of portability, not all the machines have such goodies.
I have managed to get the script to edit a line by using the output of sed and redirecting it to a new file, then copying the file back over the original. Though this seems to leave a blank line in place of the old line if I remove the files entry with the script, though editing the second field does work.
Does anyone know of a more elegant way of doing this? If not with sed then I think all of my machines do have awk if that is of any help to someone.
Cheers
Pete
PostPosted: Mon Feb 06, 2006 11:53 pm    Post subject: RE: editing text files from within the shell Reply with quote
What exactly are you trying to do to the file ? There's a good chance that both sed and awk can do what you want, but one may be easier than the other for the task you have in mind.
PostPosted: Tue Feb 07, 2006 12:46 am    Post subject: RE: editing text files from within the shell Reply with quote
If using sed, the s command only replaces content within a line, you need d to delete a complete line or block of lines.
Also, use the -i option to modify a file in place instead of sending pout put to a temporary file, deleting and renaming.
As Nigel says, a clearer idea of what you are doing will result in a clearer recommendation.
snuffsaid
PostPosted: Tue Feb 07, 2006 9:43 am    Post subject: RE: editing text files from within the shell Reply with quote
Sorry for not providing more info, I didn't want to waffle on too much. I have a thrid party application that limits the amount of logins using the application, but does not limit the number of times a user can log in. I have found a way of limiting the users to be only able to login a certain number of times by editing the apps startup script to refer to another file to see how many times that user is allowed to log in. Now I am trying to create a script that can be run from the command line so the person in charge doesn't have to use vi. All he would need to do is <command> -a (add), -r (remove) -m(modify) and so on. This would edit the file, whichis only about 20 lines long and is set out like "username:number of logins". The : can be replaced by anything really.
Hope I haven't waffled on too much and it's made things a little clearer
In the mean time I'll go and try the -i option
Many Thanks
Pete
PostPosted: Wed Feb 08, 2006 8:21 am    Post subject: RE: editing text files from within the shell Reply with quote
Information isn't waffle Smile.
Sounds like a job for "sed" though. A google on sed will come up with lots of diverse sources of information. Including histories, "examples" etc. Unfortuately the man page is quite lacking. I think that because sed has been around for such a long time, it isn't really centralised to the dgree where a single site will provide all the required documentation. So, as a result, it is scattered. Certainly, imo, one of the great unix tools.
PostPosted: Wed Feb 08, 2006 9:33 am    Post subject: RE: editing text files from within the shell Reply with quote
The sed manpage is limited, but the last paragraph tells you all you need to know, full documentation is in the info page.
You can do what you want with
Code:
#add
echo "${NAME}:${LIMIT}" >>configfile
#remove
sed -i "/^${NAME}:/d" configfile
#modify
sed -i "s/^${NAME}:.*/${NAME}:${LIMIT}/" configfile
You'll have to add the usual checks, like making sure you don't add a user twice or try to modify a non-existent user.
PostPosted: Thu Feb 09, 2006 8:52 am    Post subject: RE: editing text files from within the shell Reply with quote
Rolling Eyes , wish i had looked at the info page at the time (good_grief.png) Rolling Eyes
http://counter.li.org
alloydog
PostPosted: Thu Feb 09, 2006 1:03 pm    Post subject: Re: RE: editing text files from within the shell Reply with quote
You mean:
snuffsaid
PostPosted: Thu Feb 09, 2006 2:36 pm    Post subject: RE: Re: RE: editing text files from within the shell Reply with quote
a big thank you to you all. I was staring at the man page and even the "classic shell scripting" book late at night but just could not see for looking, as they say.
Cheers
Pete
PostPosted: Sun Feb 12, 2006 2:20 pm    Post subject: RE: Re: RE: editing text files from within the shell Reply with quote
alloydog wrote:
You mean:
In a nut shell Smile (hehehe) (um ,,, that is a jpg you know ! Rolling Eyes )
Tell me about it (grin), mind you, some of the google feed back on sed is worth the squize Wink
