Folder tree structure
Postby Brooke » Thu May 12, 2005 12:23 am
i am at school in my IT class and i need to know what a folder tree structure is, and what the rules of it? becuase i cant find it in the text book..... or anywhere else. so if someone knows please just let me know briefly what it is. PLease
RE: Folder tree structure
Postby Guest » Thu May 12, 2005 8:40 am
A folder tree structure is just a series of folders, for instance on linux you have
and so on. Then you will have sup folders:
Now as your at school your probably on windows so you will have:
C:\Documents and Settings
C:\Program Files
Then as with linux you will have sub folders. This isn't just used for the root ( / or C:\) of the sytem but could be a folder structure of your home directory, work folder etc anything.
Hope this helps and im not rambling on.
Postby grogoreo » Thu May 12, 2005 8:42 am
| Sorry didn't login.
Postby Ram » Thu May 12, 2005 10:50 am
