Syllable Network Connection
Postby Gordon » Mon Jan 16, 2006 9:18 pm
OK I've installed syllable 0.6.0 using the basic.iso from the Syllable web site.
I'm having trouble setting up the network interface. Main machine is running OpenSUSE10, eth0 using ne2k module connected to internet via ISP and DHCP, eth1 using static IP 192.168.0.1.
The Syllable machine is using and ne2k compatible network card. I want to set things up so it has static IP 192.168.0.2 and uses the SUSE machine as the gateway. I've tried looking at the docs on the syllable web site but to no avail.
Can anyone help? Do I need to install more software than the basic install?
Gordon
RE: Syllable Network Connection
Postby M-Saunders » Tue Jan 17, 2006 10:08 am
Have you tried the Network Configuration tool in the Preferences box? You can access it from the Syllable menu or by browsing the filesystem.
M
M-Saunders
Postby Gordon » Tue Jan 17, 2006 6:10 pm
Yes I've tried that but no joy so far. I'll try again later when I have more time.
Gordon
Postby Gordon » Mon Jan 23, 2006 3:53 pm
Got it working at last
Gordon
Postby M-Saunders » Mon Jan 23, 2006 4:41 pm
Excellent. Enjoy Syllable :-)
M
M-Saunders
Users browsing this forum: Exabot [Bot] and 2 guests
