hard coding keyboard input in a Bash script
Postby TonyLB » Tue Jan 10, 2006 2:45 pm
I'm trying to write a couple of Bash scripts which use utility programs that take keyboard input (eg update-alternatives --config xxx needs a choice from the keyboard.
I want to automate it from a parameter passed when the script is used. At the moment my best effort writes a file using the input parameter, runs update-alternatives redirecting input from the newly created file, then deletes the file.
There must be a better way I'm sure. How can you pass a parameter rather than use keyboard input without writing it to a file first?
Tony
TonyLB
RE: hard coding keyboard input in a Bash script
Postby nelz » Tue Jan 10, 2006 2:58 pm
echo "xxx" | update-alternatives --config <&0
echo sends the command to stdout
the pipe sends the stdout to stdin for the next command
&0 is the file handle for stdin, so <&0 redirects it to the command.
Postby CJLL » Tue Jan 10, 2006 11:03 pm
Bash scripts accept upto 9 parameters on the command line, they are named $1 to $9
#!/bin/sh
echo "Param 1: $1"
update-alternatives --config $1
Alternatively if you want your script to get interactive
!/bin/sh
echo -n "Enter your name: "
read -e NAME
echo "Hello $NAME"
update-alternatives --config $NAME
CJLL
Postby TonyLB » Wed Jan 11, 2006 3:40 pm
Thanks folks - I should have thought of echo!
Neltz's one does just what I needed.
Tony
TonyLB
Re: RE: hard coding keyboard input in a Bash script
Postby drws » Wed Jan 11, 2006 6:22 pm
CJLL wrote:Bash scripts accept upto 9 parameters on the command line, they are named $1 to $9
Don't forget ${10} ${11} ${12} etc. if you need more than 9 parameters
drws
