Rhakios Moderator
Joined: Thu Apr 07, 2005 12:18 am Posts: 7483 Location: Midlands, UK
Posted: Sun Jan 08, 2006 12:39 am Post subject: Linux Wireless Adaptors |
Just browsing around tonight, I notice that Linux Emporium are selling Linux compatible 802.11g wireless devices.
This might be useful to anyone looking for compatible hardware.
They don't seem too expensive, I might venture a purchase when I see how much I can afford at the end of the month. _________________ Bye, Rhakios |
shifty_ben LXF regular
Joined: Tue Oct 04, 2005 10:56 am Posts: 1292 Location: Ipswich
Posted: Sun Jan 08, 2006 12:46 am Post subject: RE: Linux Wireless Adaptors |
Nice to see some manufacturers supporting OSS. Hopefully more will follow suit, if enough manufacturers do it will mean one less hassle for users. _________________ Need a New Signature |
Rhakios Moderator
Posted: Sun Jan 08, 2006 12:40 pm Post subject: RE: Linux Wireless Adaptors |
Meanwhile, I think it is best to spend your money on those manufacturers who do provide some measure of support for OSS and hope the others get the message. _________________ Bye, Rhakios |
Dave2
Joined: Sat Oct 01, 2005 11:43 pm Posts: 67 Location: Bath, England
Posted: Sun Jan 08, 2006 12:56 pm Post subject: RE: Linux Wireless Adaptors |
As mentioned in a previous topic, I'm currently using one of these which uses the same rt2500 chipset. They can be a bit of an arse to get going, as the drivers aren't part of the kernel and so you need to download the drivers and kernel source (quite hard when you have no network connection ) and then compile the modules, but once that's done they work nicely. _________________ Bloat. The crappiest Perl script in the world? You decide! |
Rhakios Moderator
Posted: Sun Jan 08, 2006 2:53 pm Post subject: RE: Linux Wireless Adaptors |
I was interested in the fact that they are supposed to run OOTB with Ubuntu 5.10 (except the USB) and SuSE 10, at least according to the site I linked to. I wonder if the latest Mandriva also has the drivers. _________________ Bye, Rhakios |
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 8035 Location: Warrington, UK
Posted: Sun Jan 08, 2006 8:07 pm Post subject: RE: Linux Wireless Adaptors |
I'm using the USB version of the device Dave2 recommended. It uses a different chipset and driver, zd1211, but works perfectly. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
crispibits LXF regular
Joined: Thu Jun 30, 2005 1:33 pm Posts: 201 Location: Bath
Posted: Sun Jan 08, 2006 10:45 pm Post subject: RE: Linux Wireless Adaptors |
I can verify that rt2500's work OOTB with Ubuntu 5.10, but have found that after the last kernel upgrade it went a bit wonky. the connection seemed to oscillate. I grabbed the latest CVS from serialmonkey.com and all seems ok again now. Hope this helps someone... _________________ I'm not a spammer - honest! |
noelob
Joined: Mon Feb 13, 2006 11:09 am Posts: 45 Location: Ireland
spottedcat LXF regular
Joined: Mon Oct 31, 2005 3:14 pm Posts: 971 Location: UK
Posted: Tue Mar 07, 2006 4:07 pm Post subject: |
I have one of the Belkin PCI cards which has worked without any trouble in a Windows box for several months now. I haven't tried it in a Linux installation yet, because the OOTB drivers in Ubuntu and SuSE don't support WPA. I don't really want to use WEP - it seems a retrograde step. I'll wait.
As far as customer reviews are concerned, I'm very cynical about negative ones. They often say more about the reviewer than the product. Looking for a DVD rewriter to match my silver PC case, I found a customer review which marked the NEC ND-3540A down because although the front face was coloured silver, the tray inside wasn't - it was beige. I bought the NEC. It matches the case fine. It works fine too. The interior is beige. Who cares? |
