Suse 10.0 install problems
Postby pyro092 » Thu Jan 05, 2006 4:40 pm
As a first go at Linux I tried to install the Suse coverdisk. In all modes (including safe) the install will just hang at some stage, this seems to vary every time, though I can occasionally get to the initial setup I have never got as far as actually installing the first disk.
I have verified the CD, and even downloaded a fresh copy of OpenSuse 10.0, to no avail.
My system is rather elderly, 333MHz, AMD K6-2, 128MB, 6 GB HD, nothing else unusual. Is this computer up to the task or should I look elsewhere for a Linux setup? The whole reason I looked at Linux was to keep this old computer alive.
Any advice appreciated,
Thanks
pyro092
Postby ryptyde » Fri Jan 06, 2006 3:30 am
I just finished installing SUSE 10.0 from the LXF74 DVD on a P3 550 MHz,284MB ram,60G hdd.Everything was OK.
Just might be that a different distro is in order,try a LiveCD like Damn Small Linux it will practically
run on a matchbox and if you like it you can install to the hdd.
Damn Small Linux(DSL=50MB of Penguin Power).
DSL
Phil
ryptyde
