ggsinclair LXF regular
Joined: Thu Apr 07, 2005 8:41 am Posts: 233 Location: Linlithgow, UK
Posted: Thu Apr 07, 2005 8:50 am Post subject: Where is my MPŁ player?? |
I have got an MP3 player which was detected under MDK 10/10.1.
I am now a SuSe convert and am using 9.2 professional.
When I plug my player in it detects it under dmesg (I cannot remember what it called it!!), however, I cannot find it under devices.
How do I mount it if I cannot find it?
Thanks.
Gordon |
phil_m
Joined: Tue Apr 05, 2005 5:53 pm Posts: 18 Location: Cambridge
Posted: Thu Apr 07, 2005 2:45 pm Post subject: RE: Where is my MPŁ player?? |
| SuSE is really good at autodetecting things like mp3 players. In fact, my iPod shows up straight away. Try opening up Konqueror and type drives:/ into the location bar. It should then show you which drives are mounted on your PC, including any USB devices. |
nelz Moderator
Posted: Thu Apr 07, 2005 4:15 pm Post subject: RE: Where is my MPŁ player?? |
drives:/ is no longer supported in KDE 3.4. Use system:/ instead. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Posted: Thu Apr 07, 2005 7:34 pm Post subject: RE: Where is my MPŁ player?? |
Thanks for the advice. However, it still doesnt find it. I get this when I dmesg (sorry it is so long winded!!)
gordon@linux:~> dmesg
Linux version 2.6.8-24-default (geeko@buildhost) (gcc version 3.3.4 (pre 3.3.5 20040809)) #1 Wed Oct 6 09:16:23 UTC 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff8000 (ACPI data)
BIOS-e820: 000000000fff8000 - 0000000010000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffee0000 - 00000000fff00000 (reserved)
BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
757MB vmalloc/ioremap area available.
0MB HIGHMEM available.
255MB LOWMEM available.
On node 0 totalpages: 65520
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 61424 pages, LIFO batch:14
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 AMI ) @ 0x000fa300
ACPI: RSDT (v001 AMIINT AMIINT10 0x00001000 MSFT 0x0100000b) @ 0x0fff0000
ACPI: FADT (v001 AMIINT AMIINT10 0x00001000 MSFT 0x0100000b) @ 0x0fff0030
ACPI: DSDT (v001 SiS 735 0x00000100 MSFT 0x0100000d) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: local apic disabled
Built 1 zonelists
Kernel command line: root=/dev/hda1 vga=0x317 selinux=0 resume=/dev/hda5 desktop elevator=as splash=silent
bootsplash: silent mode.
Initializing CPU#0
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 1195.130 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 254284k/262080k available (2074k kernel code, 7124k reserved, 782k data, 212k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 2375.68 BogoMIPS (lpj=1187840)
Security Scaffold v1.0.0 initialized
SELinux: Disabled at boot.
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 0183f9ff c1c7f9ff 00000000 00000000
CPU: After vendor identify, caps: 0183f9ff c1c7f9ff 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0183f9ff c1c7f9ff 00000000 00000020
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: AMD Athlon(tm) Processor stepping 02
Enabling fast FPU save and restore... done.
Checking 'hlt' instruction... OK.
ACPI: IRQ9 SCI: Edge set to Level Trigger.
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Looking for DSDT in initrd ...No customized DSDT found in initrd!
Freeing initrd memory: 1164k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfdb01, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040715
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
Uncovering SIS18 that hid as a SIS503 (compatible=1)
Enabling SiS 96x SMBus.
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Power Resource [URP1] (off)
ACPI: Power Resource [URP2] (off)
ACPI: Power Resource [FDDP] (off)
ACPI: Power Resource [LPTP] (off)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 *12 14 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
PCI: Using ACPI for IRQ routing
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 5
ACPI: PCI interrupt 0000:00:02.1[B] -> GSI 5 (level, low) -> IRQ 5
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:02.2[D] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 12
ACPI: PCI interrupt 0000:00:02.3[A] -> GSI 12 (level, low) -> IRQ 12
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:02.7[C] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt 0000:00:0b.0[A] -> GSI 5 (level, low) -> IRQ 5
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 5 (level, low) -> IRQ 5
TC classifier action (bugs to netdev@oss.sgi.com cc hadi@cyberus.ca)
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1112898696.878:0): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
vesafb: framebuffer at 0xb0000000, mapped to 0xd0880000, using 6144k, total 131072k
vesafb: mode is 1024x768x16, linelength=2048, pages=84
vesafb: protected mode interface info at c000:557a
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 35007 bytes,<6>...found (1024x768, 21643 bytes, v3).
Console: switching to colour frame buffer device 127x43
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Using anticipatory io scheduler
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 64000K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
SIS5513: IDE controller at PCI slot 0000:00:02.5
SIS5513: chipset revision 208
SIS5513: not 100% native mode: will probe irqs later
SIS5513: SiS735 ATA 100 (2nd gen) controller
ide0: BM-DMA at 0xff00-0xff07, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xff08-0xff0f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: Maxtor 5T020H2, ATA DISK drive
hdb: QUANTUM FIREBALL EX3.2A, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: CW038D ATAPI CD-R/RW, ATAPI CD/DVD-ROM drive
hdd: ASUS DVD-ROM E616, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
ide2: Wait for ready failed before probe !
Probing IDE interface ide3...
ide3: Wait for ready failed before probe !
Probing IDE interface ide4...
ide4: Wait for ready failed before probe !
Probing IDE interface ide5...
ide5: Wait for ready failed before probe !
hda: max request size: 128KiB
hda: Host Protected Area detected.
current capacity is 39062500 sectors (20000 MB)
native capacity is 40021632 sectors (20491 MB)
hda: Host Protected Area disabled.
hda: 40021632 sectors (20491 MB) w/2048KiB Cache, CHS=39704/16/63, UDMA(100)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 hda6 >
hdb: max request size: 128KiB
hdb: 6306048 sectors (3228 MB) w/418KiB Cache, CHS=6256/16/63, UDMA(33)
hdb: cache flushes not supported
hdb: hdb1
ide-floppy driver 0.99.newide
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard on isa0060/serio0
input: PC Speaker
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 32768)
NET: Registered protocol family 8
NET: Registered protocol family 20
PM: Reading pmdisk image.
swsusp: Resume From Partition: /dev/hda5
<3>swsusp: Invalid partition type.
pmdisk: Error -22 resuming
PM: Resume from disk failed.
ACPI: (supports S0 S1 S4 S5)
ACPI wakeup devices:
PCI0 PS2K UAR1 UAR2 USB1 USB2 LAN MDM AUD SLPB
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
ReiserFS: hda1: found reiserfs format "3.6" with standard journal
ReiserFS: hda1: using ordered data mode
reiserfs: using flush barriers
ReiserFS: hda1: journal params: device hda1, size 8192, journal first block 18,max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda1: checking transaction log (hda1)
reiserfs: disabling flush barriers on hda1
ReiserFS: hda1: Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Trying to move old root to /initrd ... failed
Unmounting old root
Trying to free ramdisk memory ... okay
Freeing unused kernel memory: 212k freed
Adding 511520k swap on /dev/hda5. Priority:42 extents:1
usbcore: registered new driver usbfs
usbcore: registered new driver hub
md: autorun ...
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
subfs 0.9
Linux agpgart interface v0.100 (c) Dave Jones
agpgart: Detected SiS 735 chipset
agpgart: Maximum main memory to use for agp memory: 203M
agpgart: AGP aperture is 64M @ 0xd0000000
ohci_hcd: 2004 Feb 02 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ohci_hcd 0000:00:02.2: OHCI Host Controller
ohci_hcd 0000:00:02.2: irq 11, pci mem d0854000
ohci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
usb usb1: Product: OHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.8-24-default ohci_hcd
usb usb1: SerialNumber: 0000:00:02.2
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
ohci_hcd 0000:00:02.3: OHCI Host Controller
ohci_hcd 0000:00:02.3: irq 12, pci mem d0856000
ohci_hcd 0000:00:02.3: new USB bus registered, assigned bus number 2
usb usb2: Product: OHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.8-24-default ohci_hcd
usb usb2: SerialNumber: 0000:00:02.3
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
usb 2-1: new full speed USB device using address 2
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
NET: Registered protocol family 10
Disabled Privacy Extensions on device c037f6a0(lo)
IPv6 over IPv4 tunneling driver
usb 2-1.2: new low speed USB device using address 3
ip6_tables: (C) 2000-2002 Netfilter core team
usb 2-1.2: Product: WingMan Gamepad Extreme
usb 2-1.2: Manufacturer: Logitech Inc.
usb 2-1.3: new low speed USB device using address 4
usb 2-1.3: Product: RF USB Mouse
usb 2-1.3: Manufacturer: A4Tech
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.1 (2047 buckets, 16376 max) - 336 bytes per conntrack
ip6_conntrack version 0.1 (2047 buckets, 16376 max) - 208 bytes per conntrack
hdc: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 48X DVD-ROM drive, 512kB Cache
SCSI subsystem initialized
st: Version 20040403, fixed bufsize 32768, s/g segs 256
evdev_connect: evdev c1277460 handle c127747c name event0
evdev_connect: evdev c1277360 handle c127737c name event1
usbcore: registered new driver hiddev
Disabled Privacy Extensions on device cea85c00(sit0)
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Processor [CPU1] (supports C1)
powernow-k8: Processor cpuid 642 not supported
BIOS EDD facility v0.16 2004-Jun-25, 2 devices found
powernow: No powernow capabilities detected
parport0: PC-style at 0x378 [PCSPP,TRISTATE]
parport0: Printer, HEWLETT-PACKARD DESKJET 820C
lp0: using parport0 (polling).
[drm] Initialized radeon 1.11.0 20020828 on minor 0:
agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
[drm] Loading R200 Microcode
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
drivers/usb/input/hid-core.c: timeout initializing reports
evdev_connect: evdev cdfe49e0 handle cdfe49fc name event2
input: USB HID v1.00 Joystick [Logitech Inc. WingMan Gamepad Extreme] on usb-0000:00:02.3-1.2
evdev_connect: evdev cdfe42e0 handle cdfe42fc name event3
input: USB HID v1.10 Mouse [A4Tech RF USB Mouse] on usb-0000:00:02.3-1.3
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
Non-volatile memory driver v1.2
end_request: I/O error, dev fd0, sector 0
bootsplash: status on console 0 changed to on
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
usb 2-1.1: new full speed USB device using address 5
usb 2-1.1: Product: USB 2.0(FS) FLASH DISK
usb 2-1.1: SerialNumber: USB 2.0(FS) FLASH DISK
Initializing USB Mass Storage driver...
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: Model: Rev:
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sda: 503521 512-byte hdwr sectors (258 MB)
sda: Write Protect is on
sda: Mode Sense: 00 c0 00 80
sda: assuming drive cache: write through
sda: unknown partition table
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0, type 0
USB Mass Storage device found at 5
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
PPP BSD Compression module registered
PPP Deflate Compression module registered
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.50.69 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=64845 PROTO=TCP SPT=80 DPT=37390 WINDOW=12864 RES=0x00 ACK FIN URGP=0 OPT (0101080AD4D582E0FFFF16A4)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.50.69 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=64846 PROTO=TCP SPT=80 DPT=37390 WINDOW=12864 RES=0x00 ACK FIN URGP=0 OPT (0101080AD4D5A198FFFF16A4)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.166 DST=194.247.50.69 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=9584 PROTO=TCP SPT=80 DPT=28599 WINDOW=11792 RES=0x00 ACK FIN URGP=0 OPT (0101080AD4D3A6D7FFFF197E)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.50.69 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=64847 PROTO=TCP SPT=80 DPT=37390 WINDOW=12864 RES=0x00 ACK FIN URGP=0 OPT (0101080AD4D5DF08FFFF16A4)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.166 DST=194.247.50.69 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=9585 PROTO=TCP SPT=80 DPT=28599 WINDOW=11792 RES=0x00 ACK FIN URGP=0 OPT (0101080AD4D3E80FFFFF197E)
spurious 8259A interrupt: IRQ7.
SFW2-INext-DROP-DEFLT IN=modem0 OUT= MAC= SRC=216.90.138.204 DST=194.247.51.134LEN=48 TOS=0x00 PREC=0x00 TTL=108 ID=53516 DF PROTO=TCP SPT=4941 DPT=15118 WINDOW=8760 RES=0x00 SYN URGP=0 OPT (0204057801010402)
SFW2-INext-DROP-DEFLT IN=modem0 OUT= MAC= SRC=216.90.138.204 DST=194.247.51.134LEN=48 TOS=0x00 PREC=0x00 TTL=108 ID=53828 DF PROTO=TCP SPT=3410 DPT=445 WINDOW=8760 RES=0x00 SYN URGP=0 OPT (0204057801010402)
SFW2-INext-DROP-DEFLT IN=modem0 OUT= MAC= SRC=216.90.138.204 DST=194.247.51.134LEN=48 TOS=0x00 PREC=0x00 TTL=108 ID=54336 DF PROTO=TCP SPT=3410 DPT=445 WINDOW=8760 RES=0x00 SYN URGP=0 OPT (0204057801010402)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.51.134 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=43095 PROTO=TCP SPT=80 DPT=9287 WINDOW=6432 RES=0x00 ACK FIN URGP=0 OPT (0101080AD504889F002E2158)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.51.134 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=43096 PROTO=TCP SPT=80 DPT=9287 WINDOW=6432 RES=0x00 ACK FIN URGP=0 OPT (0101080AD5049DCB002E2158)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.51.134 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=43098 PROTO=TCP SPT=80 DPT=9287 WINDOW=6432 RES=0x00 ACK FIN URGP=0 OPT (0101080AD5051CD3002E2158)
SFW2-INext-DROP-DEFLT-INV IN=modem0 OUT= MAC= SRC=63.210.62.165 DST=194.247.51.134 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=43100 PROTO=TCP SPT=80 DPT=9287 WINDOW=6432 RES=0x00 ACK FIN URGP=0 OPT (0101080AD50718F3002E2158)
usb 2-1.1: USB disconnect, address 5
usb 2-1.1: new full speed USB device using address 6
scsi1 : SCSI emulation for USB Mass Storage devices
Vendor: Model: Rev:
Attached scsi removable disk sda at scsi1, channel 0, id 0, lun 0
Attached scsi generic sg0 at scsi1, channel 0, id 0, lun 0, type 0
USB Mass Storage device found at 6
usb 2-1.1: USB disconnect, address 6
usb 2-1.1: new full speed USB device using address 7
scsi2 : SCSI emulation for USB Mass Storage devices
Vendor: Model: Rev:
sda: Write Protect is off
sda: Mode Sense: 00 c0 00 00
Attached scsi removable disk sda at scsi2, channel 0, id 0, lun 0
Attached scsi generic sg0 at scsi2, channel 0, id 0, lun 0, type 0
USB Mass Storage device found at 7
gordon@linux:~>
Does this make any sense?
Thanks.
Gordon |
phil_m
Posted: Thu Apr 07, 2005 7:36 pm Post subject: RE: Where is my MPŁ player?? |
| drives:/ seems to work fine for me in KDE 3.4. Besides, if he's using SuSE 9.2 it's likely that he's on KDE 3.3.x unless he's upgraded with RedCarpet or something. |
nelz Moderator
Posted: Thu Apr 07, 2005 7:47 pm Post subject: RE: Where is my MPŁ player?? |
It's right there at the end of dmesg, the USB stick is at /dev/sda, so the filesystem is probably on /dev/sda1. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
nelz Moderator
Posted: Thu Apr 07, 2005 7:51 pm Post subject: Re: RE: Where is my MPŁ player?? |
| phil_m wrote: | | drives:/ seems to work fine for me in KDE 3.4. |
It definitely doesn't here, I've tried it on two computers and both give "Protocol not supported". As you say though, on a standard SUSE 9.2 setup, drives:/ will be fine. |
Posted: Fri Apr 08, 2005 9:00 am Post subject: RE: Re: RE: Where is my MPŁ player?? |
Thanks for your help with this one.
SuSe does detect it, however, when I drives:/sda or sda1 it asks me for a file association. I assumed that this was asking for a browser so I selected Konqueror. This did not work.
Am I doing something stupid?
Thanks.
Gordon _________________ Knowledge is knowing a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad. |
nelz Moderator
Posted: Fri Apr 08, 2005 9:21 am Post subject: RE: Re: RE: Where is my MPŁ player?? |
Have you tried mounting it manually, in a root terminal, with:
| Code: | mkdir -p /media/usb
mount /dev/sda1 /media/usb |
coolclassic LXF regular
Posted: Fri Apr 08, 2005 3:23 pm Post subject: RE: Re: RE: Where is my MPŁ player?? |
Suse9.0 mounted my mp3 as sda1 and sda2. On further investigation I found four partions on my mp3 player. Mine finaly worked with:
mount -t vfat /dev/sda4 /your mount point _________________ The world is your playground why don't you play. |
linuxgirlie LXF regular
Joined: Sat Apr 09, 2005 7:34 pm Posts: 787 Location: Kent...UK
Posted: Sat Apr 09, 2005 7:53 pm Post subject: RE: Re: RE: Where is my MPŁ player?? |
Ahhhhhhhh, just get yourself a Rio Karma, (not sure if this has been reviewed in LXF, but should be) I have one, and it is well worth it.
Ogg vorbis support, is just the icing on the cake! |
Posted: Sat Apr 09, 2005 9:43 pm Post subject: RE: Re: RE: Where is my MPŁ player?? |
Many thanks for your help on this one.
Got it sorted now!
