jer1ch0 LXF regular
Joined: Sat Apr 09, 2005 11:42 am Posts: 135 Location: Ireland
Posted: Sun May 08, 2005 10:43 pm Post subject: Firefox problem |
Using Suse 9.2 and just after installing Firefox. It installed it to my home directory and doesn't automatically put a shortcut in the start menu.
Where should it be installed to and how about getting that shortcut? |
Posted: Sun May 08, 2005 10:47 pm Post subject: RE: Firefox problem |
| Open the Firefox folder in your Home directory. find the Firefox icon and drag it to your launch panel. Works just fine from there. |
jer1ch0 LXF regular
Posted: Sun May 08, 2005 10:51 pm Post subject: RE: Firefox problem |
| Cheers, that works fine and I should have thought of it. Is the Firefox program folder ok in my home directory? It doesn't seem right. |
towy71 Moderator
Posted: Sun May 08, 2005 10:55 pm Post subject: RE: Firefox problem |
you didn't say how you installed it so at a guess you might not have installed it with root privileges, so the only place you could install it is in your home directory, but that is fine too as long as you know its there and don't "accidently" delete it  _________________ still looking for that door into summer |
Posted: Sun May 08, 2005 11:31 pm Post subject: RE: Firefox problem |
| Yea, I installed it as a normal user. If I had installed it as root, would it have put it into other (more appropriate) directories? |
fingers99 LXF regular
Posted: Sun May 08, 2005 11:49 pm Post subject: RE: Firefox problem |
| Yes. As would have installing it from the SuSE rpm -- except the latter would have made it rather easier to upgrade. |
fdsfsdf Guest
Posted: Sun May 15, 2005 4:47 pm Post subject: Re: RE: Firefox problem |
