dvd burning k3b with scripts?
Postby mjpwall » Wed May 04, 2005 2:17 pm
Ok here's the problem, new to linux, used to using windows and never wrote a script to do anything. Using suse 9.1. I want to burn dvd's but I want to use a kodak disc transporter which would allow me to make 75 copies at a time, it lifts the blank drops it into the drive and removes the completed disc and loads another etc. the kodak is a scsi device and my dvd writer is a usb2 device. k3b looks nice and easy to use but it doesn't have native support for the transporter, however i understand it will operate using scripts and these could alsooperate the transporter, but i've never done this in my life and don't know where to start. can anyone help?
mjpwall
RE: dvd burning k3b with scripts?
Postby Guest » Thu May 05, 2005 9:50 am
34 views and no answers, someone out there must know how to do this?
Re: RE: dvd burning k3b with scripts?
Postby mugstar » Thu May 05, 2005 7:29 pm
Anonymous wrote:34 views and no answers, someone out there must know how to do this?
Could it be that none of us can think of a legitimate reason to copy 75 DVD's at a time ? :wink:
mugstar
RE: Re: RE: dvd burning k3b with scripts?
Postby Flea » Fri May 06, 2005 12:33 am
I can think of plenty.
The question is, who cares?
Flea
Postby towy71 » Fri May 06, 2005 7:13 am
If I could work out how to write working scripts I would offer help! as it is I can only sit in the wings scratching my head in a Stan Laurel fashion ;-)
Postby nelz » Fri May 06, 2005 9:13 am
The script itself is probably quite trivial. The hard part is knowing what SCSI commands to send to the disc changer. If you knew that, you wouldn't even need K3b as the script could do everything.
