jjmac LXF regular
Posted: Wed May 04, 2005 2:56 am Post subject: Thermal Pads/Past: apparent default supplied pad |
Can't decide if this should be in mobile or here.
I purchased an Athlon64 3000+ S939 processor and an Asus A8V Mboard on tuesday.
Just looking over the fan'heatsink that came with the processor, there appears to be, what might be, a thermal pad attached to the bottom of the heatsink.
Q: Is it a thermal pad ?
Q: If so, what do people think of it's quality/reliability.
Q: What do people think of the performane expectation from the fan. It looks very much like your standard 80mm fan to me. I don't suppose AMD have built in some obsolecence there. The fan sure dosen't impress me? I will probably replace that.
Up at the local shopping center there's an outlet called "Dick Smiths", a general electronics type shop. It does carry some Thermal-Take products, mostly heatsinks and a couple of standard 80mm fans, nothing to elaborate. They do have some small tubes of "Arctic Silver" though, which i have noticed gets a good recommendation.
My main question is on this sticy, grey, pad thing, very thin and stuck to the bottom of the heatsink, and the right size and place to cover the cpu .... a thermal pad ???
There is nothing in the instruction sheet that is specific on that, (which drives me to total distraction (grin) )
For all i know it could just be a protective film, that needs to be removed, then wiped over with some iso-pro before the real past is applied.
If anyone can correct me on that,, it would be mucho grandae.
PS: The Mainboards manual is really slack i recone . I would have expected a bit more elaboration there, so it looks like it will be using mainly defaults untill i'm better informed
And it is __really__ windows specific too. Looks like open source drivers are going to have to be tracked down, before i can try to use some of the cool features Asus claim for thier board. Would have thought a major company like that would have been more Linux supportive, but ... it would seem not
We still have such a long way to go i guess...
TIA
skecs
Joined: Fri Apr 22, 2005 10:22 am Posts: 76 Location: Bathurst, NSW Australia
Posted: Wed May 04, 2005 8:55 am Post subject: RE: Thermal Pads/Past: apparent default supplied pad |
Hi jm,
Yes the grey blob is a heat pad/goo. I have installed a number of AMD processors and not had any problems running the standard AMD fan unless overclocking is involved or the room gets hot and then I usually just add an 80mm case fan extracting from the case.
Can't help with the motherboard - I haven't installed an ASUS for a while. There are number of reviews available saying they have had no problems - http://www.linuxquestions.org/hcl/showproduct.php?product=2407&sort=8&cat=all&page=1 _________________ Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered! |
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 7995 Location: Warrington, UK
Posted: Wed May 04, 2005 9:24 am Post subject: RE: Thermal Pads/Past: apparent default supplied pad |
Why would you post in mobile when this is for a desktop system?
AMD retail processor kits come with a three year warranty (OEM processors only have one year), so they aren't going to supply a sub-standard fan. It may not be the quietest fan you can get, but it will do its job of protecting the chip. The Athlon64 runs cooler than the 32bit chips like the XP, so while the fan may not look too impressive to someone upgrading from an XP, it will do the job quite well.
I transferred my watercooling kit from my XP to the 64 last year and am able to run it with everything turned down to the minimum and still run cooler than the XP. The hard drives are the noisiest part of my system now  _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
jjmac LXF regular
Posted: Wed May 04, 2005 10:35 am Post subject: RE: Thermal Pads/Past: apparent default supplied pad |
Howdy All,
It all sounds positive, (it has taken long enough to get around to too) .
hmmm, good point, i though it may have ment hw in general, but obviously not (grin). Water cooling is quite interesting. Especially if dust is an issue. which here it is. Dust filters tend to reduces air flow, leading either to higher rpms, or more fans, resulting in more noise. Yes, water sounds good. I saw a warter unit advertised the other day that used a finned convection tower to get rid of the heat. I think, i'll look into that a bit more before summer comes back around again. High humidity is about the only thing i can think of that might inhibit it, but that would be also true for air flow. It does tend to get very humid on the east coast in Aus, possibly a combo of the two would be the go there.
Thanks again for the hints:)
| Code: |
-:- If the system is the answer, then the question -:-
-:- must have been really stupid. -:-
_________________ http://counter.li.org
