[Solved] Mono and Sqlite
Postby tedius » Mon Nov 28, 2005 2:11 pm
I'm having some problems with a database application I'm writing in C# on mono. To be more precise it is the SqliteParameter object that is causing me hassle.
This is a snippet of my code;
    public static class Connection
        private static SqliteConnection mConn = null;
        public static bool Connect(string filename)
            if (mConn != null)
                mConn.Close();
            string connString = "version=3,URI=file:" + filename;
            mConn = new SqliteConnection(connString);
            return true;
        public static void Create()
            string sql = @"CREATE TABLE _table
                               (param TEXT NOT NULL,
                                value TEXT NOT NULL);
            SqliteCommand cmd = new SqliteCommand(sql, mConn);
            // insert the default values
            Insert("version", mdVersion);
            Insert("ready", true);
        private static void Insert(string var, object val)
            string sql = "INSERT INTO _table VALUES (@Param, @Val)";
            SqliteCommand cmd = null;
            SqliteParameter param = null;
            try
                mConn.Open();
                param = new SqliteParameter();
                param.ParameterName = "@Param";
                param.Value = var;
                cmd.Parameters.Add(param);
                param.ParameterName = "@Val";
                param.Value = val.ToString();
                cmd.ExecuteNonQuery();
            finally
                if (cmd != null)
                    cmd.Dispose();
                mConn.Close();
Can any one see what I'm doing wrong with this. When I run it I get the following error;
Unhandled Exception: System.ApplicationException: unrecognized token: "@"
in <0x00186> Mono.Data.SqliteClient.SqliteCommand:Prepare ()
in <0x00085> Mono.Data.SqliteClient.SqliteCommand:ExecuteReader (CommandBehavior behavior, Boolean want_results, System.Int32 rows_affected)
in <0x00023> Mono.Data.SqliteClient.SqliteCommand:ExecuteNonQuery ()
in <0x001a9> PiggyBank.Database.Connection:Insert (System.String var, System.Object val)
in <0x00040> PiggyBank.Database.Connection:Create ()
in <0x00033> MainClass:Main (System.String[] args)
Some one please help, as I'm pulling out my heir :?
[edit] ups I mean hair :oops: [/edit]
tedius
Re: Mono and Sqlite
Postby M-Saunders » Mon Nov 28, 2005 2:23 pm
tedius wrote:Some one please help, as I'm pulling out my heir :?
Hey, just because it won't run, doesn't mean you need to cut people out of your will.
(Sorry. Had to do it.)
M :-)
M-Saunders
RE: Re: Mono and Sqlite
Postby tommieb » Mon Nov 28, 2005 3:12 pm
Hmmm....have you tried taking out the @ from the param.ParameterName = "@Param"; line??
HTH,
Tom.
tommieb
Postby tommieb » Mon Nov 28, 2005 3:16 pm
Oh yeah, I'd also guess you'd have to declare the parameters in the line that contains the SQL....INSERT INTO _table VALUES (@Param, @Val), from my mssql exp, the db manager would need to know what are the parameter typings for each of them...perhaps something like this - DECLARE @Param Text, DECLARE @Val Text prior to the INSERT sql?
tommieb
Postby tedius » Mon Nov 28, 2005 3:42 pm
From what I have understand from the Mono and .NET documentation then the parameter substitution is happening before the sql is passed to Sqlite. As for the other suggestion, I tried that and it had no effect.
tedius
Postby tedius » Tue Nov 29, 2005 10:38 am
I have found out what the problem is.
I'm using sqlite3 and for this they have changed the @ for :. So once I had replaced all my @ signs with : signs it worked fine.
tedius
