Linux From Scratch
Gordon
PostPosted: Tue May 03, 2005 7:31 pm    Post subject: Linux From Scratch Reply with quote
Have any Linux Format readers attempted to install a Linux From Scratch system?
Did you come across any problems or do you have any good tips? What do you think about Linux From Scratch?
I've built a base Linux From Scratch system and am now upgrading it with Beyond Linux From Scratch. I'm using version 6 of both. So far I have the base LFS, jed editor, links browser, Xorg and fvwm2 installed. There are a few other things installed, but they are the sort of "invisible" things you don't really see; openssl, cracklib, pam, shadow, iptables etc.
As you can see I'm slowly working my way through BLFS6. I've got my broadband working and set up a firewall per the BLFS book, but I can't really tell if the firewall is working. How would I check or test this with a single machine?
The thought of having a Linux system tailored to my hardware and my wishes was just too tempting.
What do you think?
Gordon Murgatroyd
View user's profile Send private message Yahoo Messenger
PostPosted: Tue May 03, 2005 8:32 pm    Post subject: RE: Linux From Scratch Reply with quote
Try Shields Up!
Gordon
PostPosted: Wed May 04, 2005 4:05 pm    Post subject: RE: Linux From Scratch Reply with quote
Thanks for that Nelz. It appears my Linux from Scratch system is more secure than SUSE 9.3 at the moment! Maybe I need to reconfigure the SUSE personal Firewall.
Gordon
PostPosted: Sat May 07, 2005 9:10 pm    Post subject: RE: Linux From Scratch Reply with quote
I've now got the GNOME desktop working, butt appear to be having a problem with the panel icons. Any ideas out there?
I must say that Gnome feels far more responsive now it's been compiled from source.
No native GNOME apps compiled as yet though.
Rolling Eyes
Nobber
PostPosted: Mon May 09, 2005 11:02 am    Post subject: RE: Linux From Scratch Reply with quote
I first tried LFS 3.1 some years ago, and it went very smoothly and worked well. However, the BLFS book was very incomplete at that stage, and I had no idea how to get X compiled and installed properly, so I stuck with Debian for a while. A little later I tried LFS 3.3, and that also went without hitch. And by that time the BLFS book was a little more useful, so I was able to build a fully usable system that eventually became my default OS, and stayed that way for about 18 months until I upgraded to BLFS 5.0.
I use Slackware these days to avoid having to build a base system and X myself - as the parent of a small child, my computer time is limited now Exclamation - but I still find the BLFS book useful for installing stuff that doesn't come as standard with Slack.
