Supported RAID Controllers
Postby brian » Mon May 02, 2005 9:28 pm
Hi
Been doing a bit of searching but not coming up with much in the way of supported RAID controllers.
I have one based on the ITE8212 chipset, but searching shows that this has limited success on 2.6.x kernels, and its a bugger to compiles, on anything higher than 2.6.8
So I thought that I would just purchase a supported card. Trouble is not sure what is supported, I think the Promise RAID is, but not too sure about availablity of these.
Using suse 9.3, any suggestions or personal experience with recommended RAID controllers welcome.
Thanks
brian
RE: Supported RAID Controllers
Postby nordle » Mon May 02, 2005 10:59 pm
I've no direct experience, but Novell's/Suse's support database has a lot of info:
http://cdb.novell.com/productSearch.php ... s%5B%5D=28
I think, therefore I compile
nordle
