Which is the best wireless vendor/chipset etc?
Goto page 1, 2  Next
kcy29581
PostPosted: Sun Nov 13, 2005 8:33 pm    Post subject: Which is the best wireless vendor/chipset etc? Reply with quote
Hi all,
I require straight answers to questions:
- If I want to stick to a wireless vendor for Linux (as I have been doing with Linksys products for Windows) which is the best? Linksys, Netgear, Belkin or D-Link or other? Obviously the best thing would be for a vendor to say: "I support Open Source, here are the drivers, etc, and our hardware will always work with Linux!"
The above may be wishful thinking, but seriously, which is the best vendor for Linux?
Ndiswrapper is a fine approach, but does not always work nicely. Native drivers/modules are best.
Any help would be greatly appreciated, as I am trying to get my laptop wireless with Linux (either PCMCIA or USB-wise), and the rest of my home network pc's.
Thanks
There is no spoon...
Oh, and it's WINDOWS not Winblowz for those who can't spell
Dave2
PostPosted: Sun Nov 13, 2005 9:59 pm    Post subject: RE: Which is the best wireless vendor/chipset etc? Reply with quote
I own this 802.11g PCMCIA card, which uses the rt2500 chipset. There are GPLd drivers for the rt2400 and rt2500 chipsets, based on code released by Ralink (the chipset manufacturer). As they're not (yet?) part of the kernel, they can be a bit tricky to install - especially if you don't have an existing network connection (as you need to install kernel headers to compile them) - but once they're working, they work well
As an added bonus, it comes with an (ugly) Qt-based GUI config tool, which is essentially a port of the Windows config software.
There's also a fairly comprehensive list of supported cards at http://linux-wless.passys.nl/ .
Bloat. The crappiest Perl script in the world? You decide!
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
PostPosted: Mon Nov 14, 2005 10:23 am    Post subject: RE: Which is the best wireless vendor/chipset etc? Reply with quote
I like 3Com stuff... I'm happily using a 3CRPAG175 a/b/g card (the one with the pop-out antenna) with SuSE 9.2 in my laptop.
They work well with Windows too.
PostPosted: Mon Nov 14, 2005 11:43 am    Post subject: RE: Which is the best wireless vendor/chipset etc? Reply with quote
I bought a 3com card, one supported by the prism54 drivers, only to find that 3com had changed the chipset to one that didn't work with any Linux driver. There is no way to tell which chipset a card uses unless you can look at the serial number or other markings on it.
Buying any 802.11g card is a lottery, there are plenty you can be sure will not work, but none you can be absolutely certain will until you have bought them.
Dave2
PostPosted: Mon Nov 14, 2005 11:46 am    Post subject: Re: RE: Which is the best wireless vendor/chipset etc? Reply with quote
Except the one I linked to above :p.
PostPosted: Mon Nov 14, 2005 1:32 pm    Post subject: RE: Re: RE: Which is the best wireless vendor/chipset etc? Reply with quote
The specs don't say which chipset is used, so the manufacturer could change the chipset at any time and you wouldn't know until you'd bought it.
Dave2
PostPosted: Mon Nov 14, 2005 2:58 pm    Post subject: RE: Re: RE: Which is the best wireless vendor/chipset etc? Reply with quote
It's basically a commercially sold reference board, so I don't see them changing the chipset any time soon, given that they don't actually do anything with it themselves.
PostPosted: Mon Nov 14, 2005 6:40 pm    Post subject: RE: Re: RE: Which is the best wireless vendor/chipset etc? Reply with quote
Do they do a USB version based on the same chipset?
Dave2
PostPosted: Mon Nov 14, 2005 6:48 pm    Post subject: RE: Re: RE: Which is the best wireless vendor/chipset etc? Reply with quote
Not sure; I didn't look into it. I know that there are rt2500 USB devices out there, though.
PostPosted: Mon Nov 14, 2005 8:25 pm    Post subject: Re: RE: Re: RE: Which is the best wireless vendor/chipset et Reply with quote
Unfortunately, there appear to be issues with the rt2570 driver on PPC. However, Edimax do a zd1211 based USB device (unless they've changed the chipset).
PostPosted: Mon Nov 14, 2005 8:27 pm    Post subject: Re: RE: Re: RE: Which is the best wireless vendor/chipset et Reply with quote
Even that doesn't guarantee anything. 3com didn't change to a different chipset, the Prism chipset itself changed, moving firmware code from the chip to the driver and rendering the Linux driver useless. Everything indicated that the card was compatible, but it didn't work because of the chipset change. Nothing is for sure with wireless Sad
Dave2
PostPosted: Mon Nov 14, 2005 9:08 pm    Post subject: RE: Re: RE: Re: RE: Which is the best wireless vendor/chipse Reply with quote
Given that ralink release their own GPLd code, including a GUI config utility, and work with the 3rd party maintainers, I'd think that rt2x00-based wifi devices are pretty safe for the moment. It's possible that this situation could change, but it seems unlikely in the near future.
ladi
PostPosted: Thu Nov 17, 2005 8:51 am    Post subject: RE: Re: RE: Re: RE: Which is the best wireless vendor/chipse Reply with quote
I have a DWL G122 USB adapter from D-Link which works perfectly with Windows, as you would expect. The latest Linux distros - I know about SUSE 10 - will detect it and work without any configuration if you are not using encryption. I have now got it working at 54mps with WPA-TKIP under Slackware 10.1 with a 2.6.12 kernel and ndiswrapper 1.5. I am trying to figure out how to avoid having to broadcast my ESSID.
So I say D-Link gets my vote.
View user's profile Send private message Yahoo Messenger
PostPosted: Thu Nov 17, 2005 11:23 am    Post subject: RE: Re: RE: Re: RE: Which is the best wireless vendor/chipse Reply with quote
I looked at the D-Link, but the rt2570 driver appears to be problematic with PPC (this is for my iBook). So I followed Dave2's advice and looked at the Edimax. Their USB device uses the zd1211 driver, it arrived yesterday and works perfectly. I had a slight problem at first in that it would connect to the AP but I couldn't connect to anything else. It turned out that this was because I hadn't specified the ESSID and it logged ontosomeone else's AP, presumably my neighbours.
I really must let them know that their AP is unsecured (I could even log into their AP's admin interface with the default password)... as soon as I've finished sending these Viagra e-mails Very Happy
PostPosted: Thu Nov 17, 2005 12:11 pm    Post subject: RE: Re: RE: Re: RE: Which is the best wireless vendor/chipse Reply with quote
nelz - does your iBook have an airport/airport extreme card built-in ? If so, does that not work with Linux ?
I'm thinking of treating myself to a 12" iBook for Christmas as I want a useable but very portable laptop with a decent battery life. The latest ones come with Airport Extreme & Bluetooth as standard. Initially I'll run OS-X on it, but I might want to move to Linux later on (depends if I can put up with Finder or not Smile), and it would be good to be forewarned of any potential problems.
What do you think of the iBook, hardware-wise - is it as good as they claim ?
Many thanks,
Goto page 1, 2  Next
Page 1 of 2
