Bash Script to display directories in Path?
Postby debut » Wed Nov 09, 2005 7:59 pm
Hello there,
As a newbie:
The directories in PATH can be hard to distinguish when printed out as
one line with colon .Please, can i have a sample script to display
them,one to a line.
Thank you.
debut
RE: Bash Script to display directories in Path?
Postby Nobber » Wed Nov 09, 2005 9:39 pm
Try:
echo $PATH | sed 's/:/\n/g'
at the bash prompt.
Nobber
Postby Nigel » Wed Nov 09, 2005 9:43 pm
Try this command :
echo $PATH | awk -F: '{for (i=1; i<=NF; i++) print $i}'
note that the outer brackets are curly ones, the inner ones are standard brackets, the quotes are standard single quotes.
Re: RE: Bash Script to display directories in Path?
Postby Nigel » Wed Nov 09, 2005 9:46 pm
Nobber wrote:Try:
at the bash prompt.
awk vs sed... a holy war to rival vi vs emacs :D
RE: Re: RE: Bash Script to display directories in Path?
Postby nelz » Thu Nov 10, 2005 12:26 am
There are two major differences with awk vs. sed
1) You can use both
2) you can admit to using both :)
sed seems somewhat simpler for this particular operation.
Re: RE: Re: RE: Bash Script to display directories in Path?
Postby Nigel » Thu Nov 10, 2005 12:47 am
nelz wrote:sed seems somewhat simpler for this particular operation.
OK, I'll give you that one :)
Maybe it's just the people I used to work with that got polarised with one or the other. I used awk a bit, never got around to learning sed.
RE: Re: RE: Re: RE: Bash Script to display directories in Pa
Postby nelz » Thu Nov 10, 2005 9:33 am
I'm the other way around. I know sed reasonably ell and rarely use awk. awk looks a lot more powerful, but I need to read the man pages again whenever I want to use it.
Postby A-Wing » Sun Nov 13, 2005 11:24 am
I use awk all the time simply because I have never tried to use sed, a bit like Nigel really :)
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
