Adamoto
Adamoto
Postby linuxgirlie » Fri Apr 15, 2005 9:15 am
Does anyone know if this is still being pushed? I really want to for work as well as the Karoshi project, but it seems a bit buggy. I have emailed the devs but no replies, that was about a month ago....if not does anyone know a similar software system that allows both linux and windows installation of files.
If you don't know what I'm talking about go here:
http://adamoto.sourceforge.net/
:roll:
linuxgirlie
RE: Adamoto
Postby linuxgirlie » Fri Apr 15, 2005 9:16 am
Forgot to add, I have managed to bodge it together a bit, and can almost get it to work, but now I have hit a brick wall.
linuxgirlie
RE: Adamoto
Postby Guest » Wed Apr 27, 2005 8:06 am
I am working on adamoto, maybe can I help you ?
RE: Adamoto
Postby linuxgirlie » Wed Apr 27, 2005 8:10 am
That would be great if you can, basically I have two problems, the first is with the windows client and the second is with a linux client ...I got futher with the linux client, but its still not working correctly.
linuxgirlie
RE: Adamoto
Postby Guest » Wed Apr 27, 2005 11:36 am
For the windows client, i can help you, it works here.
Let me gues. you can not distribute packets ?
I can share ans install .msi files and setup files, but not the .exe files (can not install it)
I have writen a tutorial, but in french (yes i am french) but juste explain exactly your problem, and I'll try to help you .
RE: Adamoto
Postby linuxgirlie » Thu Apr 28, 2005 5:39 pm
Ok, I have two problems, one with Windows and the other with Linux.
Windows problem: I setup the client fine, though it struggles to find the right files, I haven't even gotten to the installation of files yet as I am having so many problems getting the client in working order, so I thought I would test it on a linux box...
Linux Problem: it downloads the 'test' program perfectly but fails to install it.
Have you got a link to your tutorial? I will just use an online translation tool and hope for the best...thanks,
linuxgirlie
RE: Adamoto
Postby Guest » Fri Apr 29, 2005 6:46 am
http://sites.estvideo.com/nosferatus/Tu ... damoto.doc
It can be a server problem I think.
did you test your Tomcat and apache installation ?
(http://localhost:8080)
Did you copy the packages in $JAKATA_HOME/webapps/adamoto ?
RE: Adamoto
Postby linuxgirlie » Fri Apr 29, 2005 5:52 pm
Thanks for that, I translated it, but left it at work :x so will have a go on monday....
linuxgirlie
RE: Adamoto
Postby linuxgirlie » Fri Apr 29, 2005 5:53 pm
ok duh, I work in a school, I'll have a go on tuesday!!
linuxgirlie
RE: Adamoto
Postby Guest » Mon May 02, 2005 10:04 am
I just found how to do, for my problem. Adamoto works now completely.
So for any problem, juste ask
(don't know how to translate this) Je suis à ton entière disposition.
RE: Adamoto
Postby towy71 » Mon May 02, 2005 10:31 am
I am fully at your disposal
as done by http://babelfish.altavista.digital.com
hth
Dick :wink:
Users browsing this forum: guy, Yahoo [Bot] and 1 guest
