Synaptic issue?
Synaptic issue?
Postby DavidMcCrossan » Fri Aug 22, 2014 1:39 pm
Hi guys!
Trying to install my Epson SX130 printer/copier from the cmd line I found the Epson driver, and tried to use apt-get install which reported that I had a missing file.
You can find the code files in my post of a few days ago.
I went to synaptic to try and install the missing file and the screen told me that I had some broken files. I looked at the menus and found "broken", selected it and inserted my password. Synaptic then searched for the relevant files - and there were dozens of them! - and reinstalled them.
One of the files was the Epson driver.....
I tried apt-get install and it worked a treat. Control Centre -> Printers and it installed easily.
Now here a tho't occurs to me. When and how did these files become corrupted from a new install?
Perhaps a couple of you learned guys might wish to select "broken" in synaptic and see any of you have similar issues?
Best regards
David
Semper in Excretam
DavidMcCrossan
Re: Synaptic issue?
Postby DavidMcCrossan » Tue Sep 02, 2014 1:34 pm
If you check my post on the Help forum entitled Synaptic failure there may lie the root cause of the erstwhile problem.
I have no idea how I came to be communicating with the Epson site - I did not make such a request.
Something else to ponder as it may well be related.
Best
David
Semper in Excretam
DavidMcCrossan
Return to Discussion
