tool for monitoring intermittent Broadband?
Postby fraxinus » Sat Jun 21, 2014 4:34 pm
I am struggling with intermittency with my Broadband connection - I seem to be experiencing dozens of brief breaks in service every day, which can mess up FTP transactions and downloads. Upload speed is also sometimes very slow.
I am certain these are my ISP's problem, not mine, and I am pressing them to do something about it. But I could use some data to back up my complaint.
Simple question - can anyone recommend a reasonably user-friendly tool that I can install which will gather data about the performance of my Internet connection, identifying slow periods and outages, which I can then supply to my ISP in statistical or graphic form?
Forgive me posting a query like this when clearly there are so many network monitoring tools out there, but I'd be grateful for a recommendation for this particular task.
Thanks in anticipation. I am using Linux Mint 13 64-bit, fully updated etc.
fraxinus
Postby roseway » Sat Jun 21, 2014 5:34 pm
What router do you use?
Eric
roseway
Postby Dutch_Master » Sat Jun 21, 2014 7:55 pm
Wireshark is the tool you need, IIRC it has a daemon function to have it run unattended so you can catch intermittent faults/disconnects and writes to a log file too.
Postby fraxinus » Sun Jun 22, 2014 10:24 am
Thanks to you both for your suggestions. I am installing Wireshark and will try it out!
I have been using two different Netgear routers - a wired-only DG834 and a new wireless N600. Same symptoms and issues with both.
fraxinus
