wakeonlan not waking
Postby pk_fox » Sat May 17, 2014 6:52 am
Hi all, I used to be able to wake my HP Proliant server using either Windows or Linux wol clients, however that was when it was running Windows, since installing Linux ( OpenSuse ) I can't wake it up , I've tried wakeonlan / etherwake from my Debian box and EMCO tools from a Windows 7 box ( all of which worked before ) and no worky. , I've checked the MAC address and it hasn't changed ( I have known them to change by something cloning them ) so I'm asking the experts.
We can't stop here, this is bat country. Hunter S Thompson RIP.
pk_fox
Postby bobthebob1234 » Sat May 17, 2014 11:36 am
Whenever I have used wakeonlan I've had to enable it in the OS
https://help.ubuntu.com/community/WakeOnLan
(ok ubuntu instructions but OpenSuse doesn't seem to have the same level of documentation, but I would hope
sudo ethtool -s <NIC> wol g
would work on any OS!)
bobthebob1234
Postby pk_fox » Sat May 17, 2014 11:56 am
bobthebob1234 wrote:Whenever I have used wakeonlan I've had to enable it in the OS
Hi there and thanks but I need to put
ethtool -s eth0 wol g
in a startup script to make it stick and I'm not familiar with OpenSuse so don't know where to put it
pk_fox
Postby pk_fox » Sat May 17, 2014 12:44 pm
Edit
I rebooted and ran ethtool eth0 and the output showed that the setting has stuck so it survives a reboot and the green light on the nic is on so I really don't know why it wont boot
pk_fox
Postby ferrari » Sun May 18, 2014 4:07 am
No, any settings made with ethtool will not persist through a reboot. It may be that the settings you 'applied' happen to default already. You can check with
ethtool <nic>
For example, I get
 # ethtool ens1
Settings for ens1:
        Supported ports: [ TP ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Speed: Unknown!
        Duplex: Unknown! (255)
        Port: Twisted Pair
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        MDI-X: Unknown
        Supports Wake-on: g
        Wake-on: g
        Current message level: 0x000000ff (255)
                               drv probe link timer ifdown ifup rx_err tx_err
        Link detected: no
In any case to make it persistent with openSUSE, you can add the required command to /etc/init.d/after.local and have it execute during the boot process.
There is probably another reason that WOL is not working as expected.
ferrari
Postby ferrari » Sun May 18, 2014 4:16 am
I haven't tried this, but it should also be possible to add the required ethtool options in /etc/sysconfig/network/ifcfg-<eth-id> using 'ETHTOOLS_OPTIONS=' eg
ETHTOOL_OPTIONS='wol g'
ferrari
Postby pk_fox » Sun May 18, 2014 10:16 am
ferrari wrote:I haven't tried this, but it should also be possible to add the required ethtool options in /etc/sysconfig/network/ifcfg-<eth-id> using 'ETHTOOLS_OPTIONS=' eg
The problem is it seems that the nic settings are ok, it's something else stopping it waking up, it worked perfectly when I had windows and esxi on it so it's not a hardware problem
Output from ethtool
ethtool eth0
Settings for eth0:
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: Symmetric
        Link partner advertised auto-negotiation: Yes
        Speed: 100Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 1
        MDI-X: off
        Supports Wake-on: g
        Wake-on: g
        Link detected: yes
pk_fox
Postby ferrari » Sun May 18, 2014 8:23 pm
ferrari
Postby pk_fox » Sun Jun 01, 2014 1:27 pm
ferrari wrote:Review the advice given here
https://wiki.archlinux.org/index.php/Wa ... th_systemd
Also, see my post in the openSUSE thread
https://forums.opensuse.org/showthread. ... ost2644034
Edit
One thing I've noticed is, if I power down and then unplug the power cable and reconnect it wol then works - but if I shut it down again using shutdown or poweroff it will not wake unless I go through the same unplug reconnect process which obvously is not ideal.
pk_fox
Postby ferrari » Sun Jun 01, 2014 10:29 pm
I'm not sure what else to advise here. (Perhaps it's time to try another NIC in the machine.)
ferrari
Postby pk_fox » Mon Jun 02, 2014 5:12 am
ferrari wrote:I'm not sure what else to advise here. (Perhaps it's time to try another NIC in the machine.)
Why does it work in windows then, and why does disconnecting the power work, the os is obviously leaving the nic in a state where it can't be woken, BTW I'm running Debian on it now. Thanks again for your time.
pk_fox
Postby pk_fox » Mon Jun 02, 2014 8:57 am
Hi there, I have it working,, instead of using the dual port nic of which I believe one port is designated for the integrated lights out utility I fitted another nic and it worked straight away - no ethtool or changes to interfaces file it just worked - so I don't know why wol wont work using the other nic but hey ho, thanks again for your help.
pk_fox
Postby ferrari » Mon Jun 02, 2014 9:09 am
That is good to know. :)
BTW, you might want to share the make/model, or even better the chipset of the NIC
/sbin/lspci -nnk
ferrari
Postby nelz » Mon Jun 02, 2014 9:33 am
pk_fox wrote:Why does it work in windows then, and why does disconnecting the power work
Because the Windows driver is doing some magic with the card's firmware. It may be that you need a firmware file for the card to work correctly in Linux.
Postby pk_fox » Mon Jun 02, 2014 10:45 am
/sbin/lspci -nnk
lspci -nnk|grep Ethernet
03:04.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5715 Gigabit Ethernet [14e4:1678] (rev a3)
03:04.1 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5715 Gigabit Ethernet [14e4:1678] (rev a3)
07:00.0 Ethernet controller [0200]: Intel Corporation 82574L Gigabit Network Connection [8086:10d3]
It's the Intel one that works.
pk_fox
