LXF182 code samples [Solved]
Postby timl » Mon Apr 07, 2014 8:07 am
Hi, I downloaded the code for 182 and I got a file in .tgz format. Try as I might I can not unpack this file. Any suggestions?
Cheers
timl
Postby dandnsmith » Mon Apr 07, 2014 11:36 am
That should be a gzipped tar file.
Modern tar implementations can unpack this in one go (something like tar -gzf ) or you can do it as 2 stages - gunzip it first and then tar the result.
What did you try?
Derek
dandnsmith
Postby nelz » Mon Apr 07, 2014 11:55 am
That's because the file you get is not a tarball, but an HTML error message. Something is wrong with the server setup.
Postby timl » Mon Apr 07, 2014 8:46 pm
Apologies for not posting my attempts although I think nelz may be on the money:
[tim@beiderbeck Downloads]$ tar -gzf LXF182.code.tgz
tar: You must specify one of the `-Acdtrux' or `--test-label' options
Try `tar --help' or `tar --usage' for more information.
[tim@beiderbeck Downloads]$ gunzip LXF182.code.tgz
gzip: LXF182.code.tgz: not in gzip format
[tim@beiderbeck Downloads]$ tar -xvf LXF182.code.tgz
tar: This does not look like a tar archive
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
timl
Postby nelz » Mon Apr 07, 2014 8:53 pm
Well, your tar syntax is wrong, it should be
tar xf LXF182.code.tgz
but that won't work for the aforementioned reason.
file LXF182.code.tgz
tells the real story.
Postby thorsen » Mon Apr 21, 2014 11:11 am
problems go back to 180; 179 is the last valid TGZ I could download.
180 - file consists of HTML string:
<br />
<b>Warning</b>: readfile(/var/www/files/pdfs/LXF180.code.tgz) [<a href='function.readfile'>function.readfile</a>]: failed to open stream: Permission denied in <b>/usr/share/drupal5/includes/download.php</b> on line <b>71</b><br />
181 - seems to download for ever: killed it at ~60MB
182 - like 180
183 - like 180
Really surprised this hasn't been fixed in 4 months. Does anyone responsible for this stuff ever check the forum?
http://is.gd/OY8oaV
thorsen
Postby ChriThor » Tue Apr 22, 2014 11:45 am
We haven't be able to replicate the problem, but we're checking the Drupal setup now to see if this is the cause. Thanks!
ChriThor
Postby ChriThor » Tue Apr 22, 2014 11:49 am
Files are going to the right place, but Drupal is spitting out an error when supplying them. Possibly a permissions problem. Again, we're checking.
ChriThor
Postby ChriThor » Tue Apr 22, 2014 11:53 am
Okay, permission issue it was. You should be able to download the source files without a problem. All credit to Jonni B.
ChriThor
Postby thorsen » Thu Apr 24, 2014 6:05 pm
ChrisThornett wrote:Okay, permission issue it was. You should be able to download the source files without a problem. All credit to Jonni B.
Hey there. Thanks.
I Tried 180 to 185 and only 181 still gives me problems.... unless it really is over 250 MB in size, because that's where I killed the download assuming it had gone wrong. (using Firefox)
(Perhaps you can include the sizes in the download page?)
PS. I just tried a 2nd time and it gave a failed message after a few seconds .....
thorsen
Postby ChriThor » Fri Apr 25, 2014 4:34 pm
Er, would you believe the source code is 306MB for 181... Sorry.
ChriThor
