Mount an ISO in Windows 7
Postby heiowge » Mon Feb 10, 2014 9:28 pm
Does anyone know how I can mount an ISO file in Windows 7? The file is too big for me to burn to DVD (over 6GB).
There are lots of "recommended" tools for Windows, but I trust them about as much as I trust a politician.
Postby purplepenguin » Mon Feb 10, 2014 10:25 pm
Back in the day I used to use Deamon Tools Lite and Virtual Clone Drive from Slysoft.
purplepenguin
Postby Ram » Mon Feb 10, 2014 11:17 pm
2nd PP and DTL
Failing not trusting Windows tools, can you get your hands on a dual layered DVD, you can burn upto 8gb.
You could mount or extract it in your fav distro and copy over to Windows or to an external drive. As it can be extracted maybe it might be possible to use zip / rar or 7z in Win7 these days.
Postby lok1950 » Tue Feb 11, 2014 5:14 am
And if you have the Nero suite one of the apps in it will mount .iso images.
Enjoy the Choice :)
lok1950
Postby dandnsmith » Tue Feb 11, 2014 8:05 am
I use something, which I believe is a tool provided with Win7, to mount CD iso files. It is WinArchiver Virtual Drive. I suggest you hunt for it, as I've forgotten how I got hold of it, and it doesn't give many clues when running.
Derek
dandnsmith
Postby heiowge » Wed Feb 12, 2014 3:43 pm
I got winarchiver virtual drive. It doesn't seem to do anything but install itself. :shock:
Postby heiowge » Wed Feb 12, 2014 3:59 pm
Second time lucky. Daemon Tools Lite did the job. My son is very happy. :D
Cheers guys.
Postby dandnsmith » Thu Feb 13, 2014 8:00 am
I've been using it long enough to remember that you have then to run it, when it appears as a parcelled box in the tray which can be used to mount/unmount the required iso files.
I'm glad you're happy with Daemon Tools - I wouldn't touch it with the proverbial, after it made a real mess of one system some years back.
Derek
dandnsmith
