GRUB boot loader prob on SUSE 9.2
moshshockerz
PostPosted: Fri Apr 29, 2005 12:59 pm    Post subject: GRUB boot loader prob on SUSE 9.2 Reply with quote
i,ve just installed my SUSE 9.2 via GHOST.i,ve sucessfully duplicate the hardisk.but my prob is i can't boot, it,s required the root password for maintenance manually.the error message is "fsck fail".i don't know what is the problem, because i,ve been ghost the hardisk for many times but the results is still the same. i'm not also familiar with LINUX. i choose to ghost the hardisk because there is a software that need to be configure by a programmer that we develope ourselve. and this pc will run as a server and we need to make it about 100. if i do the fresh install then we need to configure it again and again.what is the problem and how can i fix it???
PLEASE HELP ME....... Question
dandnsmith
PostPosted: Sun May 01, 2005 12:12 pm    Post subject: RE: GRUB boot loader prob on SUSE 9.2 Reply with quote
Whatever else it is, this isn't a GRUB problem per se.
The fact that you're saying that you need to fsck the filesystem suggests that there may be something lost in copying (perhaps to do with the journalling files).
I don't know why, if you are doing things like this, you don't have the root password - you need to get it. For all we know you're just trying to bypass system security without permission, so I won't offer any assistance in this respect.
Derek
fingers99
PostPosted: Sun May 01, 2005 4:07 pm    Post subject: RE: GRUB boot loader prob on SUSE 9.2 Reply with quote
If you do have the root password, then you can run fsck manually:
fsck /dev/(partition)
I'm not sure how well Ghost works with Linux filesystems. You might find that partition image does a better job.
