Help with PATH
Postby nelz » Sun Jan 12, 2014 7:15 pm
That would do it, I have no such command in /etc/X11/xinit so it appear to be either a distro or DE addition.
So my previous point stands, you cannot guarantee ~/.profile being executed on every system.
Help with PATH
Postby DavePritchard » Mon Jan 13, 2014 11:21 am
Thanks for all the replies, unfortunately I got confused and totally lost by it all.
The PATH needs to be changed for just one programme, the XDS M2 Compiler, the system is KDE with just me as the user.
I tried the following, but the result means nothing to me.
CODE
grep profile ~/.bash*
/home/dave/.bash_profile:# .bash_profile
I also tried :-
grep ~/.profile and cat ~/.profile
with no result.
(why why why is Linux so user hostile )
DavePritchard
Postby MartyBartfast » Mon Jan 13, 2014 12:08 pm
I think what it boils down to is go with my original suggestion (the first reply), everything since has been an interesting diversion, which you don't need to worry about.
MartyBartfast
Postby nelz » Mon Jan 13, 2014 1:04 pm
That is the best solution, much of the continuing discussion was about why other suggestion were less reliable.
It's not that Linux is hostile, just that some programs are inconsiderate in going about things their own way when there is already a perfectly acceptable way of doing things, resulting is too many confusing choices. That's the price of freedom.
Help with PATH
Postby DavePritchard » Mon Jan 13, 2014 10:07 pm
but I am now totally confused.
The PATH needs to be changed just for one programme, ie the XDS M2 Compiler, the system is KDE with just one user.
~/.profile does not exist.
As suggested I tried the following, the result is meaningless to me.
CODE
/home/dave/.bash_history:grep profile ~./bash*
/home/dave/.bash_history:grep profile ~/.bash*
/home/dave/.bash_history:grep ~/.profile
So perhaps I should try /etc/profile, but where in the following do I insert the
/usr/local/xds/bin statement.
CODE ( /etc/profile ).
# /etc/profile -*- Mode: shell-script -*-
# (c) MandrakeSoft, Chmouel Boudjnah <chmouel@mandrakesoft.com>
loginsh=1
if [ "$UID" -ge 500 ] && ! echo ${PATH} |grep -q /usr/games ; then
PATH=$PATH:/usr/games
fi
umask 022
USER=`id -un`
LOGNAME=$USER
MAIL="/var/spool/mail/$USER"
HISTCONTROL=ignoredups
HOSTNAME=`/bin/hostname`
HISTSIZE=1000
if [ -z "$INPUTRC" -a ! -f "$HOME/.inputrc" ]; then
INPUTRC=/etc/inputrc
fi
# some old programs still use it (eg: "man"), and it is also
# required for level1 compliance for LI18NUX2000
NLSPATH=/usr/share/locale/%l/%N
export PATH PS1 USER LOGNAME MAIL HOSTNAME INPUTRC NLSPATH
export HISTCONTROL HISTSIZE
for i in /etc/profile.d/*.sh ; do
if [ -r $i ]; then
. $i
fi
done
unset i
DavePritchard
Help with PATH
Postby DavePritchard » Mon Jan 13, 2014 10:14 pm
Confusion abounds, I missed the second page, oops.
DavePritchard
Users browsing this forum: Bing [Bot] and 6 guests
