Password not accepted Ubuntu 12.04
Postby Cushie » Wed Jan 08, 2014 12:53 pm
I have had repeated problems trying to get Ubuntu to accept my password, which I know is correct.
Not the latest computer, Athlon 3.2 Gb 2 GB memory. 32 bit.
I bit the bullet and from LXF coverdisks tried a fresh install of 13.10 which failed to install, then 13.04 which also would not install so back to 12.04 coverdisk and installed that (probably keeping my original home partition.
Originally I had set automatic install but nevertheless was presented with the login screen but my password was not accepted. If I booted into recovery mode my same password was ok!
I then opted to boot as 'Guest' and with sudo accepting my password I reset my 'name' user to the original password, logged out but still can not log in.
I created a new user 'name1' using the same password and can get access every login ok.
I would like to solve mu original login problem out of interest sake.
If I cannot solve that, is it Ok to delete the original 'name' directory after I have transferred my home documents to the new user?
Your suggestions appreciated.
Regards.
Cushie
Postby nelz » Wed Jan 08, 2014 1:02 pm
What is the exact error message you get? Are you sure it is a password error? From your description, this could also be caused by incorrect permissions/ownership on files used by your desktop, which are fixed with
sudo chown -R username: ~username
Postby Cushie » Wed Jan 08, 2014 5:46 pm
Thanks Nelz, I think you may have it, that was my suspicion.
the error is login password incorrect.
To use chown I can log in as root or admin on 'name1'
then, do I need to 'chown' when I am in that directory Home/name?
" sudo chown -R username: ~name "
I shall certainly try that.
Regards.
Cushie
Postby nelz » Wed Jan 08, 2014 6:19 pm
~username is the home directory of that user, you don't need to give the explicit path - which may or may not be /home/username.[/quote]
Postby Cushie » Thu Jan 09, 2014 7:00 pm
Thanks Nelz you hit it on the head!
At first I got 'username:' unrecognised, then I substituted my login 'name' for 'username' and eventually separated 'name' and ':' thus:-
" sudo chown -R name : ~name "
How does the space before ':' change the meaning?
Well I got the login accepted even though I messed up the desktop layout, but I can proceed therefrom, thanks a lot.
Regards.
Cushie
Postby nelz » Thu Jan 09, 2014 8:53 pm
There shouldn't be a space between the username and the :
Postby Cushie » Fri Jan 10, 2014 12:25 pm
Ok, thanks. Much appreciated.
Regards.
Cushie
