Can't delete corrupt file
Postby heiowge » Thu Dec 26, 2013 8:41 pm
Direct deleting gives:
Any ideas? :?
Postby nelz » Thu Dec 26, 2013 8:50 pm
Looks like it could be filesystem corruption. What does ls -l say about the file?
You may need to unmount the filesystem (or boot from a live CD) and run fsck on it.
Postby heiowge » Thu Dec 26, 2013 8:59 pm
$ ls -l
total 2131656
-rw------- 1 ****** ****** 719959780 Jun 19 2012 ********
drwx------ 1 ****** ****** 4096 Apr 6 2013 Pauls backup
drwx------ 1 ****** ****** 4096 Oct 14 23:23 Rach's backup
-rw------- 3 ****** ****** 733734912 Mar 21 2012 ******
-rw------- 2 ****** ****** 729108480 Mar 21 2012 ******
Bottom two files are the ones that won't delete.
***edit*** Forgot to say, it's an external hard drive.
Postby nelz » Thu Dec 26, 2013 11:29 pm
You've obfuscated important information. Is the owner of the files the same user that mounted the drive? Does the same user own the directory containing these files, and what are the permissions on that directory. If everything is OK, unmount the fileystem and fsck it.
Postby guy » Fri Dec 27, 2013 12:02 pm
Worth going in as su or similar to override any wobbly permissions?
