Opening .ppp files in Ubuntu 12.04
Postby catgate » Thu Dec 12, 2013 1:07 pm
I have a few old *.ppp files (Serif I think) that I would like to open.
So far I have found little on tinternet that points the way. Am I wasting my time looking, or does some kind person know the secret???
Oh, sod it.
catgate
Postby wyliecoyoteuk » Thu Dec 12, 2013 2:09 pm
pagepluspublisher file
probably wasting your time.
Postby johnhudson » Thu Dec 12, 2013 9:22 pm
Not tried it with Page Plus but, if the text is in ASCII, Kate will often open a file and you can extract the text - but not the images of course.
From the command line:
strings -a --encoding={b,l} -n 2 <filename>
may work if there is any ASCII text in them.
Postby catgate » Fri Dec 13, 2013 1:16 pm
Thank you both.
I think it is a lost cause. I shall just give them the "coup de grâce".
Oh, sod it.
catgate
Postby Rhakios » Fri Dec 13, 2013 4:19 pm
When I was faced with a similar problem some years ago, I got Windows 98 up and running in a virtual machine, installed a print to pdf app and exported all my old, otherwise unreadable files to pdf.
Postby catgate » Sat Dec 14, 2013 10:19 am
Rhakios wrote:When I was faced with a similar problem some years ago, I got Windows 98 up and running in a virtual machine, installed a print to pdf app and exported all my old, otherwise unreadable files to pdf.
Thank you for that Rhakios.
That's a cunning plan deserving at least 10/10.
However I discarded all my old M$ CDs about 3 years ago, when we moved, and I feel I would rather loose my ppps than use any M$ stuff again (even 98, which, compared to it's successors, was a litle pussycat).
Oh, sod it.
catgate
Users browsing this forum: Google [Bot] and 5 guests
