MATE on Debian Stable (wheezy)
Postby guy » Fri Nov 08, 2013 12:05 pm
So then I thought, let's be brave (for me), before upgrading to Jesse I'd try upgrading my poor broken Wheezy desktop. So I sort of followed the advice on LinuxG, but instead of sudoing all the time I opened a root shell and did:
$ add-apt-repository 'deb http://repo.mate-desktop.org/debian wheezy main'
$ apt-get update
$ apt-get --yes --quiet --allow-unauthenticated install mate-archive-keyring
$ apt-get update
$ apt-get install mate-desktop-environment-extra
Very nice, just a couple of issues:
First, the MATE desktop help is broken, I am getting "package not installed" type messages. Any ideas on how to fix that? Specifically, I want to move the bottom panel to the top of the screen.
Secondly, in the synaptic Software Sources dialog (Settings > Repositories) the tabs and most of the tabsheet contents are white text on a pale grey background, quite unreadable. A few tabsheets have patches of black text. Any ideas on what options to change to get black text throughout, and where/how to access those option settings?
Plan B is to try installing the more recent Jessie instead but if it suffers the same issues I'll still need answers.
"Klinger, do you know how many zoots were killed to make that one suit?" — BJ Hunnicutt
Postby guy » Fri Nov 08, 2013 7:45 pm
After a bit of fiddling:
Text colour problem solved with a change of theme.
Panels moved by [Alt]-Left-drag.
Still no desktop help though. Hopefully I won't need it anyway, the MATE desktop is intuitive enough for a bit of fiddling to resolve these things, I had almost forgotten what that feels like. It's good.
:D
Postby nelz » Fri Nov 08, 2013 8:48 pm
Which missing package is it complaining about? It may be looking for Yelp, the GNOME help browser.
Postby guy » Fri Nov 08, 2013 8:51 pm
nelz wrote:Which missing package is it complaining about? It may be looking for Yelp, the GNOME help browser.
It just says something at help:mate[whatever] is not installed.
Postby guy » Sat Nov 09, 2013 2:55 pm
And this morning, DISASTER! After powering up and logging in the "busy" pointer whirls away and hangs. I can still log in to GNOME Classic, but MATE has exploded. Any ideas?
Postby lok1950 » Sat Nov 09, 2013 4:37 pm
Have you checked xsession errors?
Enjoy the Choice :)
lok1950
