MATE on Debian Stable (wheezy)
Postby guy » Fri Nov 08, 2013 12:05 pm
So then I thought, let's be brave (for me), before upgrading to Jesse I'd try upgrading my poor broken Wheezy desktop. So I sort of followed the advice on LinuxG, but instead of sudoing all the time I opened a root shell and did:
$ add-apt-repository 'deb http://repo.mate-desktop.org/debian wheezy main'
$ apt-get update
$ apt-get --yes --quiet --allow-unauthenticated install mate-archive-keyring
$ apt-get update
$ apt-get install mate-desktop-environment-extra
Very nice, just a couple of issues:
First, the MATE desktop help is broken, I am getting "package not installed" type messages. Any ideas on how to fix that? Specifically, I want to move the bottom panel to the top of the screen.
Secondly, in the synaptic Software Sources dialog (Settings > Repositories) the tabs and most of the tabsheet contents are white text on a pale grey background, quite unreadable. A few tabsheets have patches of black text. Any ideas on what options to change to get black text throughout, and where/how to access those option settings?
Plan B is to try installing the more recent Jessie instead but if it suffers the same issues I'll still need answers.
Postby guy » Fri Nov 08, 2013 7:45 pm
After a bit of fiddling:
Text colour problem solved with a change of theme.
Panels moved by [Alt]-Left-drag.
Still no desktop help though. Hopefully I won't need it anyway, the MATE desktop is intuitive enough for a bit of fiddling to resolve these things, I had almost forgotten what that feels like. It's good.
:D
Postby nelz » Fri Nov 08, 2013 8:48 pm
Which missing package is it complaining about? It may be looking for Yelp, the GNOME help browser.
Postby guy » Fri Nov 08, 2013 8:51 pm
nelz wrote:Which missing package is it complaining about? It may be looking for Yelp, the GNOME help browser.
It just says something at help:mate[whatever] is not installed.
Postby guy » Sat Nov 09, 2013 2:55 pm
And this morning, DISASTER! After powering up and logging in the "busy" pointer whirls away and hangs. I can still log in to GNOME Classic, but MATE has exploded. Any ideas?
Postby lok1950 » Sat Nov 09, 2013 4:37 pm
Have you checked xsession errors?
Enjoy the Choice :)
lok1950
