No ubuntu advanced options in grub menu.
Postby justmeg » Sun Sep 22, 2013 7:37 pm
Hi
I erased pre-installed windose 8 on laptop, then installed Ubuntu 13.4 secure remix, to dual boot with a kids distro Qimo.
I installed all the personal data and settings then promptly forgot the password. I tried to enter recovery mode on both Ubuntu & Qimo but neither will open to allow me into root.
I installed qimo & ubuntu in legacy mode. The bios on the laptop is Efi so I disabled fast boot & secure boot and enabled CSM .
The grub config. is as follows:
Linux 2.6 . 32 . 21 generic Linux 2.6.32 .21 (Recovery mode)
mem test (mem test 86+) mem test (mem test 86+) serial console 115200.
This is 1st boot which is Qimo
1) Ubuntu --class ubuntu --class GNU Linux --class Gnu -class OS Gnu
2) Ubuntu with Linux 3.8.0.30 generic --class Ubuntu --class Gnu Linux
3) Ubuntu with Linux 3.8.0.30 generic (recovery mode) -- class Ubuntu
4) Ubuntu with Linux 3.8.0.19 generic --class Ubuntu --class gnu Linux
5) Ubuntu with Linux 3.8.0.19 generic (Recovery Mode) --class Ubuntu _
As indicated no Ubuntu Advanced Options.
I tried all the items listed as "Recovery mode". All items have a right pointing arrow at the end of each line. I tried using the arrow key, enter key, and shift with both the arrow and enter keys but nothing worked. All produced just a blank screen.
The arrow key & enter key booted to both OS ok.
Is there any other way to enter root to change passwords please.??
Has this been caused by Efi bios (another attempt by windows to mess up Linux)
My PC dual booting win 7 and Ubuntu 13.04 enters root option via Ubuntu advanced options/recovery. Any ideas please. Just dont want to have to re-install Ubuntu. Thanks.
new to linux and need loads of help please. thanks M
justmeg
Postby purplepenguin » Sun Sep 22, 2013 7:53 pm
Try changing to, or booting into single user mode (runlevel 1). You will have a root prompt where you can change passwd.
Good Luck
purplepenguin
Postby justmeg » Sun Sep 22, 2013 8:10 pm
Thanks PP. very new to Linux so please could you explain how to do this.
Cant find much on the forums or internet relating to this so just wondered if it was a bit unusual???
Thanks again
justmeg
Postby purplepenguin » Sun Sep 22, 2013 8:16 pm
Just thought of another maybe easier way.
if you can boot the OS as normal, open a terminal and
SU (to become root)
Then type:
 passed (username)
You should be prompted as follows
Changing local password for [username]
New Password:
Retype New Password:
purplepenguin
Postby justmeg » Sun Sep 22, 2013 9:00 pm
Sorry PP didnt work. Requires existing password to generate new one. Back to the problem cant remember the pw that I initially used. What a plonker !!! When one is the wrong side of 70 these senile moments occur. :lol:
Please define how to do this ref: your previous post.
T
Again many thanks for your help and patience.
justmeg
Postby justmeg » Sun Sep 22, 2013 9:22 pm
Found where I had written it. had tried it many time without success but then realised that I had entered it in caps.
Used your post to change it to lower case.
I would still like to try to find out why the recovery mode does not work so will keep trying.
again many thanks for your help. meg
justmeg
Postby purplepenguin » Sun Sep 22, 2013 9:44 pm
justmeg wrote:Sorry PP didnt work. Requires existing password to generate new one. Back to the problem cant remember the pw that I initially used. What a plonker !!! When one is the wrong side of 70 these senile moments occur. :lol:
T
To boot into single user mode:
At Grub highlight the OS your after.
Press "e" to edit.
Arrow down and type "single" (no quotes) after ro in the line that starts linux /boot/vmlinuz.
press F10 to boot.
You will be dropped to a root prompt #.
Now type:
passwd (username)
EDIT
I see you have it sorted now. :D
purplepenguin
Postby justmeg » Sun Sep 22, 2013 10:04 pm
yes, but still very useful information . Going to give it a go now.
I have bought lots of book,s downloaded lots of pdf tutorials but for me applying instructions like this is a good way of learning.
Thanks
justmeg
